Go to Post why would someone do that? Go on the internet and tell lies? - MaGiC_PiKaChU [more]
Unread 09-02-2006, 14:19
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Six-axis positioning sensor suggestions
Does anyone have suggestions for an inexpensive six-axis positioning sensor (three accelerometers and three gyros mounted orthogonally)? I don't need anything fancy like Bluetooth or USB... analog outputs would be fine. I recall seeing one recently, but I can't remember the website. Any help would be much appreciated.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 09-02-2006, 23:04
Jared Russell's Avatar
Taking a year (mostly) off
Re: Six-axis positioning sensor suggestions
Finding a pre-built six-axis INS that is under $200 and still reasonably accurate is nigh on impossible.
Why not buy three gyros and three accelerometers if you are going this route, and assembling them into your own custom unit?
Unread 10-02-2006, 14:20
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
I don't know that I have the mechanical skill to build something as accurately constructed as something that is predesigned.
_
Unread 10-02-2006, 15:07
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
It all depends on what you are going to be using this for, there are other ways that you can do the same thing but with different data and sensors. And a six axis positioning sensor under $200 would be VERY hard to find.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 10-02-2006, 16:57
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
I'm trying to construct an absolute positioning system for a robot I'm working on. I would want it to be able to work on a variety of surfaces, on ramps, in elevators... just about anything. I don't think that mere encoders will cut it. I'm open to suggestions, but I'm leaning toward a six-axis system.
_
Unread 10-02-2006, 17:02
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
It is not what you asked for but it may be helpful just the same.
http://www.sparkfun.com/commerce/pro...roducts_id=244
A 3 Axis magnetometer.
Check it out.
Joe J.
Team #88, TJ2
Unread 11-02-2006, 00:52
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Check it out.
Joe J.
Okay, I read through the data sheet, but I'm not quite sure how this helps with positioning. Could you please explain, Dr. Joe?
_
Unread 11-02-2006, 01:07
Joel J's Avatar
Joel J Joel J is offline
do you..
Don't use it. You can factor out the magnetic field induced by your robot, and you can calibrate for the offset caused by being indoors (these two things take work, however), but you can't account for random ferrous (would stick to a magnet) bodies in motion.
GPS would be a major help to you, if you were operating primarily outdoors.
Joe J. has a good point, though: you need some sort of stable reference to "zero out" your position error every once in a while.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 11-02-2006, 11:27
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Something like the Sparkfun 6-axis IMU would work, which is $300 when you drop the bluetooth module ( http://www.sparkfun.com/commerce/pro...roducts_id=411 ).
I don't think you are going to find an off-the-shelf 6-axis sensor for $200. I think you need to rethink your requirements, as anything in the "affordable" range isn't going to be sufficient to use for navigation. I hope this isn't going to be the only source of navigation information for whatever project you are going to use this on - as gyro's and accelerometers both have drift issues.
You can pick up three ADXRS300EB's from analog devices for like $50 each, plus accelerometer(s) by Freescale, Analog, etc and build one yourself, simply on PCB or something. Shouldn't require that much mechanical skill. (Sparkfun sells the Freescale 3-axis thats on the IMU board for like $40 IIRC).
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 11-02-2006, 11:43
AKA: Dr. Joe
FRC #0088 (TJ2)
accelerometers and angular rate sensors do not give you position either. You need to do some processing to figure things out.
You are going to have to have reduntant sensors to make this work no matter how you slice it.
I would guess that you will have to have wheel encoders plus some other info that will let you know when not to trust your encoders (due to an incline or wheels slipping or whatever). Part of the other info could be provided by this micromag sensor.
It is a complex problem that is sometimes call "sensor fusion."
Your brain does this all the time:
  • Sometimes you use your eyes
  • Sometimes you trust your inner ear
  • Sometimes you trust your sense of touch
  • Sometimes you barf your guts out because your sensors don't agree with eachother and your brain doesn't know WHAT to do ;-)
The MicroMag sensor is not a solution. It may be part of the solution.
Good luck keeping your robot from barfing!
Joe J.
Team #88, TJ2
spherical positioning sciguy125 Technical Discussion 11 16-11-2005 23:22
controlling just x or y axis of a double articulated arm Leav Programming 8 06-02-2005 14:50
Absolute Positioning System Help Tom Bottiglieri Programming 5 05-02-2005 10:32
White Paper Discuss: Code and Walkthrough for Global Positioning System using IR Sensors CD47-Bot Extra Discussion 2 20-05-2004 21:22
positioning system srjjs Technical Discussion 5 05-04-2003 14:49
