Go to Post I've never seen a spam bot edit posts before - Vikesrock [more]
Unread 09-02-2006, 17:23
Walkin Stummik's Avatar
Walkin Stummik Walkin Stummik is offline
FRC #1451
Walkin Stummik is an unknown quantity at this point
Stupid Flex Modifier *Kicks it*
Hey i've got a robot that has two antenna. I've applied a vertex selection modifier right below a flex modifier to make the attena wobble whenever the the head moves. It works great except that the center for the Flex stays in one place even as the Character moves. This makes the antenna flex badly in the opposite direction it normaly would. How do I get the flex center to move with the antenna?
Any help would be appriciated.
Pic below illistrates the problem.
Unread 09-02-2006, 18:39
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
Re: Stupid Flex Modifier *Kicks it*
havn't tried flex, but try to link the center to the head. should work
Unread 10-02-2006, 01:57
MiNT MiNT is offline
AKA: oj
None #1489 (Blood Sweat and Gears)
MiNT is an unknown quantity at this point
Hm, thats pretty odd. I tried to replicate your problem, but I wasn't able to. The 'center' should stay in position relative to its selection, which is weird. Unfortunately, I don't think you can reparent it to anything since it isn't an object in itself.
How do you have your robot animated? Are the parts linked by parenting, or is it a more complex rig?
Unread 10-02-2006, 12:33
Pachu Pachu is offline
CoPresident HRT
AKA: Piyush Agarwal
FRC #0670 (Homestead Robotics Team)
Pachu is an unknown quantity at this point
Send a message via AIM to Pachu Send a message via MSN to Pachu Send a message via Yahoo to Pachu
Hey, check the pivot of your object, it could be the pivot is back there and thats probably whats messing it up. Umm I think you can change the pivot under the hierarchy tab! Hope this helps
Unread 10-02-2006, 18:27
JakeOfIron JakeOfIron is offline
Paradox or Oxymoron?
AKA: Jake Bleier
FRC #0234 (Cyberblue)
Team Role: Animator
JakeOfIron is an unknown quantity at this point
Send a message via AIM to JakeOfIron
I feel your pain, we're using the biped this year, and we've had some... interesting problems, we already fixed it (though it was VERY time consuming) but when the head was moving into the chest when we tried to move the skull I felt the same frustration.
I just asked and sorry, no one here knows anything about the flex modifier, though usually if you mess around with the settings for long enough you'll find what your looking for.
"It's one of the joys of robotics, hearing the sweet song of the CNC."
-Anthony Chastain
If a render fails in the computer lab and there's no one there to see it, do the animators cry?
Yes.
Unread 11-02-2006, 12:51
FRC #1451
Ok yah thanx that was it. It's working now
Stupid physics problem. Adam Y. Math and Science 21 11-02-2005 06:20
This might sound stupid [programming hardware questions] Code\\Pilot Programming 1 24-01-2005 20:21
Arggg stupid css design..... Adam Y. Website Design/Showcase 16 22-04-2004 19:37
Time to feel stupid.... Anthony Kesich Programming 10 08-01-2004 15:10
