Go to Post A wise man told me a few nights ago, that it is important to own up to all your mistakes, so that others can see you doing that and wont deny and try to hide their own. - Josh Hambright [more]
Unread 10-02-2006, 08:09
Joshua Lynn Joshua Lynn is offline
FRC #0423 (SEC Mechanical Mayhem)
Joshua Lynn is on a distinguished road
File inclusion issue:
Add a .h file in the File Inclusion dialog does not seem to make the file appear in the code window as a #include
using a .h seems to be the only way to easily include structures and external functions that aren't in a .lib
How do you link other .c files for functions written elsewhere
Unread 10-02-2006, 08:34
koenig3456 koenig3456 is offline
Programming Coach
None #0681 (EARTH Squad)
koenig3456 is an unknown quantity at this point
Re: File inclusion issue:
The header files that you add to the file inclusion dialog are put into main.h.
You can link other .o files (.o files are what you get after compiling .c files) by adding them to the linker script used by EasyC. Just add FILES commands into the script following the existing ones. If you installed EasyC in the default location, the linker script for the 2006 RC is Crogram FilesIntelitekeasyC for FRCFrc18f872218f8722.lkr.
.hex file too large for 2004 controller? AL_E Programming 6 21-01-2006 22:54
C HELP PLEASE sglegend11 Programming 4 14-11-2005 21:35
Dashv2.ocx dependency file now available archiver 2000 0 23-06-2002 22:00
A file size issue Funkymunkey90 3D Animation and Competition 2 05-02-2002 14:50
