Go to Post at what point does gracious professionalism turn into cut throat competition? - aepstein [more]
Unread 10-02-2006, 22:31
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Question JB weld question...
A while back... I suggested using the wonderful J.B. weld as a perminant solution, and The team thought that it wasn't the best Idea, because we thought that it was more of a "fix it" product than a production product.I was just wondering weather or not anybody on this forum has any experience with the stuff and if your results were good. I have used it before... and it held allright, plus the user reviews all seem to be astounding... But if you've had any bad experiences with it, please post them here
Thanx in advance
-CodyC
Unread 10-02-2006, 22:36
Re: JB weld question...
epoxy is stronger than the resin used in fiberglass construction (boat hulls, car bodies...)
it is definately a production quality material, and JB weld is one of the best epoxy products on the market.
the storys about it are true. I fixed a leak in the oil pan (small hole on the side) on my Fiero, and it lasted 3 years at least (I sold the car)
Unread 11-02-2006, 00:00
DonRotolo's Avatar
Back to humble
FRC #0832
Funny, I used JB Weld for the same purpose, reinforcing the hole with a screw. Held up great.
JB Weld is a fairly good adhesive and an excellent filler. It has a lot of compressive strength, moderate shear, and poor tensile strength. It adheres well under poor conditions (heat, oil, chemicals) but isn't as good underwater. I knew a fellow who repaired a crackled engine block with it, that's where I first heard of it (over 20 years ago!!)
There are far stronger adhesives, like the clear stuff in a doiuble-tube syringe from Radio Shack (and others), but these are poor fillers. I recommend buying a small package and playing with it, you;'ll learn what it can and cannot do.
Hope that helps.
Don
Unread 11-02-2006, 00:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I've seen a FIRST robot with its drive gearboxes held together by a similar product (it was titanium-filled, instead of steel-filled like J.B. Weld). It worked...but wasn't pretty.* I'd advise against that particular application.
When using it, watch out for the fact that it slumps as it dries, so it can be tricky to apply precisely to oddly-shaped surfaces. (I've also used a Devcon-brand aluminum-filled epoxy that is of a thicker consistency, which is more easily applied to complex shapes.) Also, though it's stronger than fibreglass resin, if you're using significant quantities of it as a structural reinforcement, it should itself be reinforced with something like a fibreglass mesh.
*The team was 919, Harbord C.I., in 2002.
Unread 11-02-2006, 00:54
What Tristan said - I recently was suprized to learn that while epoxy is curing at first it gets more runny, then it gets thicker as it hardens.
Question of the Week!!! (8/24/04) Andy Grady General Forum 27 27-08-2004 19:00
Question of the Week!!! (7/19/04) Andy Grady General Forum 23 23-07-2004 13:21
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
Question About Welding Eric Bareiss Technical Discussion 6 03-05-2003 12:54
