Go to Post Change your process to change your product. - Justin Montois [more]
Unread 11-02-2006, 23:39
rushrtr3 rushrtr3 is offline
FRC #0131
rushrtr3 is an unknown quantity at this point
Exclamation NEED HELP RUNNING MULTIPLE FUNCTIONS AT SAME TIME!!
Ok I was wondering if there is a way in "easyC" to run multiple functions, while loops, or for loops at the same time? I have 6 or more that I need continuosly running. Any help would be greatly appreciated!
Unread 12-02-2006, 02:01
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: NEED HELP RUNNING MULTIPLE FUNCTIONS AT SAME TIME!!
Last I knew, the FRC was a "sequential" execution controller. Or "single-task" controller. I believe what you are asking is if you can do a "multi-task" or "multi-threaded" applications. The answer I think you'll find is “no” you can not do that.
However if you post a little more information about your application, maybe some of us can suggest other ways of how to execute your function you require in a "sequential " process of the CPU.
State programming is a wonderful way to start a process, and let the cpu pointer keep going into your loop to service other functions such as sensor updates, PID loop, etc…then come back to the state, and check to see if your process is done, if it is done, increment the state to the next step, then test against it with a while loop.
Here is a short clip from last years code. State Programming:
//ok crap, we drove out and can't see anything so let's look around.
		//first pan to the left, if we see something lock on then continue and finish this command
		//if we don't see anything left after a another timeout, then pan to the right
		//if we don't see anything right, well I guess we are just stuck....
		switch(update_pan_flag)
			case 0:
				if (thumbwheel == 31)
					update_pan_flag = 4; //thumbwheel is 31, we are on the right side skip looking left
				else
					set_pan = 100; //set default left camera pan (about 45 degrees is = 85)
					printf("Set Camera Pan Default to Left Scan...STATE=%d\r",update_pan_flag);
					update_pan_flag = 1; //next state;
				break;
			case 1:
				camera_set_servos(set_pan,128); //set camera pan and tilt
				printf("Write the Pan Servo (%d) to Vision...STATE=%d\r",set_pan,update_pan_flag);
				update_pan_flag = 2; //next state
				break;
			case 2:
				camera_find_color( GREEN ); //make camera look for green again, because when you write a pan varible it turns off camera
				printf("Look for GREEN Color Again...STATE=%d\r",update_pan_flag);
				update_pan_flag = 3; //next state
				break;
			case 3:
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
A time for reflection as we approach 2005 Ken Leung General Forum 7 07-11-2004 20:55
Unanswerable Questions!! Devin L. Chit-Chat 52 04-08-2004 22:19
time change... David Kelly Chit-Chat 9 01-11-2001 11:20
need help with time zone! Ken Leung General Forum 6 25-06-2001 12:44
