Go to Post Here's my standard for-every-new-member-of-Chief-Delphi-Welcome: WELCOME TO CHIEF DELPHI!!!!!! :D - [more]
Unread 12-02-2006, 17:47
Timer questions
I've been asked to find this out by our programmers. Is Timer1 setup with an internal oscillator? What's the frequency? Is an external oscillator necessary or legal?
Can you take over Timer0 if your aren't using PWMs 13 through 16? It's in last year's documentation, but we didn't see it in this year's.
Thanks in advance.
Unread 12-02-2006, 18:09
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Timer questions
Thanks in advance.
All the timers are based off of the microcontroller's crystal clock, which runs at 10MHz.
I didn't even know there was a Timer 0!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 12-02-2006, 18:21
Re: Timer questions
Thanks in advance.
On the 8722 we have timers 0-3 available with the 10MHz internal (an external oscillator is not needed).
Using Timer0 holds for this year as well. You need to use FRC_alltimers.lib rather than FRC_library.lib in your project just like last year.
Unread 12-02-2006, 19:24
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Timer questions
There are actually 0-4 timers and 0 is not being used for the ccp modules. Kevin Watson's ADC code uses timer 2.
And toword the end of this thread(http://www.chiefdelphi.com/forums/sh...ad.php?t=43358) I have explained that the processor runs at 10MHz hence the 10 MIPS but the external oscillator runs at 40 MHz.(if you want to understand the hardware little bit better)
You can use all the timers using Kevin Watson's interrupts code.
How To Ask Questions the Smart Way Brandon Martus General Forum 8 27-03-2013 15:52
EasyC Timer and Gyro questions TubaMorg Programming 11 09-02-2006 21:19
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
Accelerometer code ImmortalAres Programming 28 04-06-2005 01:02
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
