How to lose that extra weight (Was: Major Help!!)
our robot is 15 lbs over weight.
we need all the advice we can get to help us LOSE THE WEIGHT! any suggestion would be appreciated...thanks. |
Re: Major Help!!
If you posted a picture, it would probably help others offer advice.
Re: Major Help!!
are you aware that they changed the rules: this year the robot is weighed withOUT the battery?
Re: Major Help!!
If you are using the kit frame, drill out all of the holes in it to one drill size larger (I think its 3/8 not sure...) this takes about 3-4 lbs out of the frame while keeping the integrity.
Lexan panels love hole saws and so do metal plates as well as wooden parts. Wheels could use some holes drilled in them, not too many though. Gears should be turned down to a smaller hub, but not too small. And then holes can be drilled in them as well. Next is the electrical where wires can be shortened to exactly the length needed so as not to have extraneous wiring. Then after that replace all of your team identification panels and things with a simple piece of paper, nothing fancy. Round the corners on everything, surprisingly this takes off quite a bit. Bolts that are too long should either be cut off or replaced. Steel shafts should be traded out for aluminum ones if there isn’t a large load on them. If this doesn’t work then take off some features or remove the least necessary structural supports (not advised). Just drill holes until it looks like Swiss. You wont be the only one! Quote:
Re: How to lose that extra weight (Was: Major Help!!)
Also you can change out hardware that isn't truly load bearing from steel to aluminum and even nylon nuts and bolts instead of the standard steel.
Electrically, shorten the runs up and even electrical systems to keep the high voltage cables as short as possible, eg victors right next to the distribution block, right next to the battery and motor. Lastly replace any tubing with thinner walled tubing and lexan with thinner lexan, 1/16 to 1/32 |
change you sprockets to aluminum.
www.andymark.biz sells exact replacements to the ones in the kit but are much less in weight. |
#7
Re: Major Help!!
^ one negation too many here? the robot is weighed with out the main (big) battery this year, but the backup 7.2 V battery must be present - correct? |
#8
Re: Major Help!!
327 1/2" holes in 1/8" thick 6061 aluminum makes you loose 1 pound if you have alot of frame material
#10
BE CAREFULL if you start drilling holes in your robot to drop the weight because you dont realize how addictive it becomes
and sooner or later you end up with stuff like this in your pocket and you dont remember how it happened! ![]() |
#11
i like the pattern... except i think drilling gets annoying. already ive drilled over 100 1/2in holes all over... we still need to drop more if we want to protect stuff.. |
#12
Pay attention to the above quote. 327 1/2 in holes is a LOT of work for 1 lb. Look at a lighter design first. Remember; Steel 1rst, then Aluminum, then Plastic Get the biggest "bang for your buck" |
#13
Re: Major Help!!
Seriously, I'm glad you're removing weight now, since I don't recommend this approach. Lose the weight now, and not later. |
#14
It's late in the building season but re engineering certain components give you the chance to improve upon them as well as losing weight...
#15
you can save yourself from drilling speed holes by meerly replacing whatever material sheet you have with something thinner. Just think about how many speed holes you need to drill before you cut the weight of something in half.
| Robot Weight Limit: Rule Conflict | Specialagentjim | Rules/Strategy | 10 | 06-08-2005 17:52 |
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| weight advice | SharkBite | Technical Discussion | 36 | 15-02-2002 07:30 |
