Go to Post How many FIRSTers would quit if they found it was bad for them? I think most FIRSTaholics are thirteen steppers ;) - phrontist [more]
Unread 13-02-2006, 17:59
rsharpe rsharpe is offline
FRC #1093
Team Role: Electrical
rsharpe is an unknown quantity at this point
Exclamation PLEASE RESPOND: all fans on 1 circuit?
for the past three years i've been wiring all muffin fans to their own 20 amp breakers. Because they draw so little current and would be fine clumped together on one circuit, i would like to do this for simplicity and was wondering if there are any rules against it.
thanks for the help,
russell
Unread 13-02-2006, 18:06
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: all fans on 1 circuit?
How is that simpler? You can wire them all to the input side of the victor.. which ensures that when the speed controller has power, the fan has power. Seems like a safer approach to me.. no chance of operating a speed controller without cooling.
Unread 13-02-2006, 18:12
FRC #1093
yes that what i've done for the fans cooling the victors...i'm talking about the large muffin's and other smaller ones used for ventilation and cooling motors throughout the bot.
Unread 13-02-2006, 20:44
hooking extra muffin fans all to one breaker is ok.
I suggest you take an old motor apart sometime and look at how its constructed. The amature inside the motor does not touch the case at all, and that is what turns into a space-heater when you stall the motor.
The drill motors and FP motors have internal blowers that suck air across the windings. The CIMs are sealed and have no internal airflow.
The point is, blowing air across the outside of the motors is 99% psychological. It will have no effect on the windings inside the motor. If you tend to overheat your motors you need to gear down your geartrains to keep the motor RPM higher.
Circuit design help - power supply - Non FIRST Josh Siegel Electrical 31 24-12-2005 13:47
Are fans required? mechanicalbrain Electrical 10 27-11-2005 18:24
Questions on Muffin Fans sanddrag Electrical 6 22-01-2005 10:57
GO Marlins! Tytus Gerrish Chit-Chat 26 17-10-2003 20:44
