Go to Post Inaccurate data is not data. It's guessing. - George1902 [more]
Unread 15-02-2006, 16:53
RC randomly resets or goes into program mode
As the topic says, our RC randomly resets or goes into program mode. I was able to isolate the problem to a group of printf()'s executing every program loop, but it seems to be happening again even with those gone.
We are running Timer 2 to run the ADC (only channel is a 50Hz sampling gyro), Timer 3 for an ultrasonic range finder, and 3 hardware interrupts (2 128ppr encoders and the range finder)
Any ideas? It may be our code is taking too long to execute, but I was under the impression the master processor would totally shut down the system if this happened. And even if that happened, what would cause program mode to trigger?
Unread 15-02-2006, 17:08
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: RC randomly resets or goes into program mode
Check for dust particles near the RESET/PROG contacts.
Also, try reflashing the Master Code, something may have gotten corrupted. Were you operating in a very low power condition? Sometimes that can make memory in Atmel AVRs corrupt, PICs may have the same affliction. I'd say a Master Code redownload, followed by (not before!) a user code redownload will most likely fix your problem, but I'm not an IFI techy.
Matt Krass
Unread 15-02-2006, 17:22
Is your code sitting and spinning on the done bit of the timers?
while (timer not done yet)
do (nothing)
or something like that?
that would crash your code if its waiting too long.
Unread 15-02-2006, 19:04
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
We had this sort of trouble when our serial cable was too long. You might try using a shorter/better one.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 15-02-2006, 23:32
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We just had this tonight....we didn't have the backup battery plugged in, and the main battery was low. When the motors turned on, it rebooted the CPU.
You don't have the same issues do you?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
What type of autonomous mode program are you using? SilverStar Programming 1 21-01-2004 18:48
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
