Go to Post So.... football pizza water game with minibots and megabots? - euhlmann [more]
Unread 16-02-2006, 19:24
sjung9442 sjung9442 is offline
Student Mentor
FRC #0122 (NASA Knights)
sjung9442 is an unknown quantity at this point
ADC problem
All of our analog inputs appear to be outputting the same value, that of channel 1. We are using the ADC code from Kevin's site, integrated into his camera code. We don't know what is wrong with this code...
Can anyone help us? or had same problem?
Unread 16-02-2006, 20:06
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: ADC problem
Posting the code that you're using is probably the best way to get help...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 16-02-2006, 21:53
Re: ADC problem
If you're using Kevin's ADC code, you cannot use the usual Get_Analog_Value() function. I don't have the files handy to check, but the proper function to use is documented in his code.
(You also need to make sure you've defined the proper number of analog channels; that too is documented.)
Unread 17-02-2006, 11:00
Student Mentor
Re: ADC problem
I can't put any code here because we don't even know what the problem is...
it's so sad that we don't even know the problem...
we used Get_ADC_Result(channel number) function from kevin's code to get the value. And we set it to the analog inputs we needed... but when we turn on the robot and try to get data, we are getting 1888 for all of them...
And when we change one thing, everything changes too.
Unread 17-02-2006, 11:12
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: ADC problem
Can you zip up your project and send it to me to look at. Also, what kind of sensors are you using on the analog inputs?
-Kevin
Kevin Watson
http://kevin.org
ADC code effecting motor outs??? Kyveck Programming 16 28-03-2006 15:12
adc code problem railerobotics Programming 6 24-01-2006 22:26
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
Programming Gyros goegan31 Programming 33 19-05-2003 20:05
The problem with scouting... archiver 2001 10 23-06-2002 23:49
