Go to Post A lot of students decribe FIRST as the best thing that happened to their life. Once a student gets hooked, they don't want to leave FIRST for any cause. I am one of them. - Arefin Bari [more]
Unread 17-02-2006, 17:41
shorterboarder shorterboarder is offline
FRC #1410
shorterboarder is an unknown quantity at this point
Fans from last year
Our teams was wondering if we could use the fans (any size) that were provided in last years kits. We need to know this because our motors are heating up. Thanx
Unread 17-02-2006, 17:48
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Need Help
You have to use the fans included in this year's kit, if you choose to use fans. In general, if you motors are too hot fans won't help - you should clear the air vents or reduce the load on your motor instead.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 17-02-2006, 22:30
in between teams
AKA: Luke Van Oort
Re: Need Help
Where did you read this rule? Teams use many non kit fans, such as lighted computer fans.
Team 1219: 2009 - Mentor
Unread 17-02-2006, 22:42
Re: Need Help
<R25> Motors, pumps, and, robot controllers from previous robots may not be used in addition to those provided
in the 2006 kit of parts.
I didn't see an exception for fans, although I may be wrong...
Unread 17-02-2006, 22:46
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Need Help
Can you cite a rule that permits non-kit fans?
Fans have motors. Teams are limited to using only motors provided in the KOP and two additional CIM motors. Therefore, no non-KOP fans are allowed.
-dave
Unread 17-02-2006, 23:03
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Need Help
-dave
However... that being said, What you can do is remove the motor from one of the Papst fans and put it into a new fan housing. It's a bit tricky but if you have a need for a specific housing it's doable.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 17-02-2006, 23:07
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Need Help
innovative.....but not slick enough I'm afraid
Originally Posted by Section 5
<R36> So that every robot’s maximum power level is the same, the motors in the kit may not be modified in any
way, except as follows:
• The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the
physical connection of the motor to the robot and actuated part.
• The gearboxes for the Fisher-Price, and Globe motors are not considered “integral” and may be separated
from the motors. FIRST will not provide replacements for parts that fail due to modification.
• The electrical input leads on the motors may be trimmed to length as necessary.
I do believe taking the housing off the papst fans would not be legal according to R36
Unread 17-02-2006, 23:12
Re: Need Help
The fan housing parts are not considered mounting brackets? It is what you use to mount the fan. Also under all that plastic or metal is a motor if thats left unmodified is it really breaking the rule? I guess this would be for Q&A...
Unread 17-02-2006, 23:13
dlavery's Avatar
Curmudgeon
Re: Need Help
I stand corrected (partially - if and only if the motor can be removed from the fan housing without altering the motor itself [see above post] I have not yet looked closely enough at the kit fans to verify if this is possible, so I will give the benefit of the doubt for the moment) (I also give partial points to Jason Morrella, who pointed out that if you take the motor out of the non-KOP fan, and just stick the blades and shell on the robot, then it would be legal - after all, no one ever said that the fan actually had to do anything. Leave it to the English teacher to come up with that answer... ).
Anyway, to revise my point, if you want to use a non-kit fan (with a motor in it so it actually works, and without replacing the fan motor with one from the 2006 KOP) you may run afoul of the rules.
-dave
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
NBA or WWE you decide... Kyle Love Chit-Chat 62 24-11-2004 09:15
How did you thank your engineers/mentors/sponsors this year? Bharat Nain Thanks and/or Congrats 15 01-08-2004 21:18
Starting a college team mtrawls Starting New Teams 23 28-04-2004 09:58
Next year: Make the game understandable archiver 1999 23 23-06-2002 22:53
