Go to Post Good judgement is the result of Experience. Experience is the result of Poor Judgement. - ChrisH [more]
Unread 19-02-2006, 12:19
Back after 4 years off
FRC #5279
Auto aim in user control mode
We have written a very effective auto aim routine that works perfectly in autonomous that we also plan to use under user control . However we are having issues with incorporating the function in the user mode. We tried calling the function as well as posting the raw code in the section between get data and put data (I believe it is call process data from mater mp) we also commented out the pwms for our turret in the default routine so they were noit mapped to joysticks. Any help or sample code would be great.
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 19-02-2006, 12:24
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Auto aim in user control mode
We'll probably need some more info about your problem. What exactly happens? Posting the code would help us.
Unread 19-02-2006, 12:58
FRC #5279
It runs just like it did before the routine was added, THe drive remains the same, I will post the code later when I have the laptop.
If any one has a sample of their user code where they added there own routines and could post that or email it to me jamesbrown830@gmail.com that would probably be all that I need.
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Reputation Level suggestions Brandon Martus CD Forum Support 42 10-01-2004 08:58
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
User mode toggling JLambert Programming 2 25-02-2003 05:47
Select button and user mode n[ate]vw Programming 2 20-01-2003 16:33
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
