Urgent help needed : Camera locks on to no apparent target! ?!?!
I'm thinking this is some wierd serial port bug or something... but basically the "red" locked light is going on the camera stops searching even when nowhere near the target, even with my hand over the lens...
this doesn't happen all the time but intermittently |
Re: Urgent help needed : Camera locks on to no apparent target! ?!?!
I have the same problem. Let me know if you find the solution. This mostly happens if for some reason the Robot Controller does not start the camera functions or initializes it. |
By any chance are you two using custom code (not Kevin's code)?
If so, I discussed something similar here: http://www.chiefdelphi.com/forums/sh...threadid=44281 |
no it's all kevins
This has been discussed elsewhere. You can search and find stuff on it. But in tracking.c it checks if there is a light or not to scan because for some weird reason it gets x and y values even when the light is not in front of it. To correct that change the line if(T_Packet_Data.my != 0) to if(P_Packet_Data.confidence != 0).
Since the first post said the problem persists if a hand is in front of the camera then I do not believe that is the problem they are having. When I leave my hand in front of the camera for 3-5 seconds the search routing starts up again. |
#7
I am using Kevin's frc_camera_s, as in the no bells and whistles. This sometimes happens even using the default hex file from Kevin. |
#8
-Kevin |
#9
We are having the same problem, except we dont have it on autonomous mode. We just try getting the camera to track during normal run and the camera has the red light on. Without it moving at all. Im gonna try that change in the code and see how it works.
EDIT: Okay I changed it and this is what I get when I try to compile it. C:\frc_camera2\frc_camera\tracking.c:97:Error [1105] symbol 'P_Packet_Data' has not been defined C:\frc_camera2\frc_camera\tracking.c:97:Error [1151] struct or union object designator expected Last edited by Idaman323 : 20-02-2006 at 17:21. |
#10
-Kevin |
#11
I'll see if i can post the code tomorrow,
#12
1. Low Backup Battery (happens every hour or so!) 3. Fluorescent lighting (very tricky due to the moving particles in the rods) 4. A reflection 5. Low main battery 6. The robot was reset with the button or was too fast 7. Loose wire or a wire plugged in backwards (this was caused a tragedy on ship day when we were practicing driving) 8. Confidence value too low 9. Programming error (luckily we haven't had this yet) 10. A random error that seems to fix itself after some tinkering and resetting (least common because that would be too easy, but it happens) If you have gone through this list and changed the line in your code that the other posters are suggesting, and it still tracks ghosts, then it is over my head! |
| CMU Camera kills robot controller if not found. | Chris_Elston | Programming | 21 | 27-03-2006 14:30 |
| Camera shows no love to drive motors | anifinder | Programming | 4 | 13-02-2006 10:31 |
| Camera pointing error? | Craig Putnam | Programming | 14 | 21-01-2006 02:52 |
| For anyone who doesn't get the camera code..... | Jake M | Programming | 8 | 16-01-2006 18:56 |
| CMUCam2 Camera Code - Are important parts commented out? | Mr. Lim | Programming | 4 | 14-01-2005 12:11 |
