cmuCam2 Stoped working
I was at a practice competition and our robot took a good hit to the camera. the camera was well protected but after that the camera would not work. when we finished that round i disconnected the camera from the robot and connected it to LabVIEW. i tried to grab frame but all i saw was purple with a two or three small blobs of green.
i had the camera board form last year with me so i put this years lens on the board and tried that with LabVIEW. It worked but when i tried to connect it to the robot it couldn't communicate. is the 2005 camera not compatible with code for the 2006 cam? and how can i correct this . is this just bad luck or are the cameras that fragile? |
Re: cmuCam2 Stoped working
Last years camera is exactly the same as this years camera. So it should work perfectly. Thanks for the heads up about fragility, I will make sure to get mine neatly encased in some Lexan. |
| CMUcam2 Serial Port Diagnostics | Kevin Watson | Programming | 13 | 18-02-2006 15:05 |
| Camera isn't working | Idaman323 | Programming | 13 | 15-02-2006 23:18 |
| What I'm Working On | Jared Russell | Programming | 2 | 18-01-2006 02:34 |
| CMUcam2 disclaimer | Cody Carey | General Forum | 4 | 12-01-2006 01:19 |
| I'm working :) | Jack | FIRST Scouting Network | 2 | 03-01-2004 01:26 |
