Go to Post The mission is to mobilize community, school and corporate resources to support the vision. The method is to provide an interesting, exciting program that gives young people opportunities to explore and expand their capabilities and interests. - Rick TYler [more]
Unread 20-02-2006, 08:24
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Dewalt Shifting Questions
A question for the teams who have successfully shifted the Dewalt XRP's.
Does it make a difference how you control your servos to shift? We are presently running both servos off a single PWM Y-cable, so that we only need to use one variable in the code. The alternative is to run two different PWM cables and use a second variable in the code. This isn't a difficult thing to implement, it's just a pain to switch it over at the moment.
Our concern is this... Since the servos are powered through the PWM cable, and we're presently splitting that with a Y, are the servos only receiving 1/2 of the power they require?
Thanks for all the help.
BEN
Unread 20-02-2006, 10:32
Bruce C.'s Avatar
Bruce C. Bruce C. is offline
#0647 (The Cyber Wolf Corps)
Bruce C. will become famous soon enough
Re: Dewalt Shifting Questions
BEN
We are using the Y-cables to shift both servos at the same time. Actually, we are using two Y-cables to shift 4 servos at the same time (two sets of CIMs and DeWalts on each side.) It works fine.
Unread 20-02-2006, 12:08
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
if you are having trouble shifting the dewalts using the set-up described in the whitepaper, it may be because of the indexing clip; there is a small metal clip that serves as a spring that helps keep the dewalt in gear; unfortunately, it also makes it hard to shift using the servo. if this is removed, the servos shouldn't have any problem.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 20-02-2006, 13:40
Bengineer
Problem solved. It was a combination of a low backup battery (which powers the servos) and one of the dewalts with a sticky shifter. We replaced one entire side and it works just fine.
Thanks for the help with the Y-cable. And yes, we have already removed all the detent clips.
BEN
How To Ask Questions the Smart Way Brandon Martus General Forum 8 27-03-2013 15:52
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
