Go to Post If you are "retiring" the old ball, make all the lights green, hang it 8 feet in the air, line up a bunch of 'bots and let 'em shoot poofs. RoboPinata! (warning kids - don't eat the "candy" that falls out!) - Taylor [more]
Unread 20-02-2006, 10:49
iplayfast iplayfast is offline
None #1901
iplayfast is an unknown quantity at this point
Code Error after reset
When we download the code, it runs perfectly. After pushing the reset switch, it gets a code error. Of course we can't debug it, cause we just reset it.
What we've done is add Kevin's Camera and Serial Code and tracking code with changes added to the tracking code.
We've also taken out the original serial code (as per instructions) and initialized the new serial code.
I'm suspecting the serial code (which is interrupt driven) is not being initialized properly and is causing our headaches.
Has anyone else come across this? Is there a way to debug this?
Unread 20-02-2006, 12:34
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
Re: Code Error after reset
Have you tried commenting out the existing interrupts?
I found that when I added the serial code interrupts I needed to remove the default ones for it to work.
Unread 20-02-2006, 12:35
None #1901
Yes, that was done.
Code malfunction after robot reset? jgannon Programming 6 01-03-2006 14:42
Problem with idata_user_routines.o? Adrien Programming 3 12-02-2006 01:33
Code runs only once, fails on reset roknjohn Programming 7 21-02-2005 20:24
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
