Go to Post I design gears and gear boxes for a living. I am HAPPY to write a check and have a solution in mailed to me. - Joe Johnson [more]
View Poll Results: What can your robot do in autonomous mode?
Shoot through center goal 67 59.29%
Unload balls in corner goal 54 47.79%
Pull out 37 32.74%
Drive around 50 44.25%
Other 31 27.43%
Nothing 14 12.39%
Multiple Choice Poll. Voters: 113. You may not vote on this poll
Unread 23-02-2006, 12:00
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
What can your robot do in Autonomous?
Just curious what people plan to do in autonomous and what they are capable of.
Are you making more than one auto? Which one do you plan to do the most?
If you plan to shoot in auto, are you using the camera or dead reckoning?
Our team has more than one auto and plans to use the shooter the most.
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
Unread 23-02-2006, 12:05
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: What can your robot do in Autonomous?
I think our plan is to drive forward just a tad, and lock onto the green target and then shoot 10 balls in.
That's the plan anyways. Auto-mode wasn't proven extensively due to time constraints, but when we did, it worked.
Actually, we can drive to the floor goal as well and drop balls their too.
So, I guess we have 2 solid ones as of now.
Unread 23-02-2006, 12:10
Here is what the software people planned:
1. Drive out a few feet (selectable before start).
2. Turn towards goal.
3. Drive towards goal a few feet (selectable before start).
4. Turn control over to camera-based aiming algorithm.
5. Score ten balls with Sidewinder-like precision.
What has actually been tested:
1. Drive out a few feet.
2. Spin in place.
3. Ram the lockers at max speed.
We tested autonomous once before the robot went in the crate...
Unread 23-02-2006, 12:29
pwilczynski's Avatar
pwilczynski pwilczynski is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1993
pwilczynski is on a distinguished road
We didn't even get to test it. Everything is written, but.....you never know.
Unread 23-02-2006, 13:16
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
2. Spin in place.
Nice! If you had been at the Wildstang Invitational, you could have seen such great auto modes as:
Back up full speed into the robot behind us
Run out towards our goal. Luckily it didn't shoot!
Position perfectly in front of the opponent's goal--and just sit there!
We have since corrected those problems, and can shoot all 10 into the center goal after plopping down in front of it.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 23-02-2006, 18:22
nehalita's Avatar
Robots are friends
AKA: tagger fanatic
are you people using the camera for these?
MIT '10
Unread 23-02-2006, 18:35
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Wow, I'm shocked how many people can do somethign this year. Last year, had this poll been answered honestly, I'd say less then 50% could do anything in auto.
Of course there is a great deal of self-sampling bias, and chiefdelphi is not even close to representative of FIRST, but if this is even close to true it will be a much more interesting year this year.
I'm using the camera, and two quaderature encoders. I'm using the quaderature encoders in a somewhat... unusual way. The omniwheels are undriven, being used only for navigation (and as "casters"). Since omniwheels measure rotation only in one direction, polling the encoders gives vectors which can be integrated to give position. We'll see how it works
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 07-03-2006, 18:44
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
That is because this year the object that the camera is seeking and will not really change color depending on other lights. Also you aren't aiming for something on the floor, you are aiming above you, which also makes it a little easier than last year.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 08-03-2006, 11:19
Caleb A. Caleb A. is offline
FRC #0932 (Circuit Chargers)
Caleb A. is an unknown quantity at this point
Great job guys. I was able to very easily program to dump into the corner goals, and I tried to make it shoot into the goal. But since I only got to test the day before ship day and there were a lot of kinks we're probably just be doing the side goal. But I'm going to also try shooting over a short robot into the corner goal for fun.
"If you're not FIRST, you're last."
Unread 08-03-2006, 12:01
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
Heh - please note this poll is hardly representative of robot capabilities. Around 10% of the bots I saw at Pac. NW can acutually shoot in autonomous.
As for our robot, we move forward, aim, control the turret, and then shoot balls through the hoop. We can normally get 3-4 balls into the goal.
Unread 23-02-2006, 18:40
Eldarion's Avatar
We are!
-- Thomas Paine
-- Anonymous
Unread 23-02-2006, 19:09
Umm Errr...
We can in theory:
*Drive closer to the center goal and shoot some balls in (not 10 though) using the camera. This is yet to have really been tested, but it should work once i tune our feedback loops a little better.
*Drive to some random place on the field using timing
1139 Alumni
Unread 23-02-2006, 19:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think our plan is to get about 10 feet away from the center goal, lock on with the camera, aim, and then fire about 7 balls in.
Unread 23-02-2006, 19:51
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Yep..
Thanks to the camera we will be able to shoot 10 balls in a very minimal amount of time.
-Pavan
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 23-02-2006, 20:05
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Our programmer worked hard to get the camera to work and it paid off. Not only are we accurate during the match, but during autonomous as well. We are able to drive out towards our goal and shoot all 10 balls in. We have tested it and it is working quite well. I dare to say we are ready for the regional next week?
GO 1403!!!
Team 1403 is Proudly Sponsored By:
Code malfunction after robot reset? jgannon Programming 6 01-03-2006 14:42
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
