On compile: "Coff file format for 'ifi_library.o' is out of date."
I read this:
http://www.chiefdelphi.com/forums/sh...=ifi_library.o Though they get the same error it does not seem to address my issue. When ever I try to compile I get this error: Code:
MPLINK 4.02, Linker Copyright (c) 2006 Microchip Technology Inc. Error - Coff file format for 'ifi_library.o' is out of date. Error - Could not build member 'ifi_library.o' in library file 'C:\Documents and Settings\Erik\Desktop\TRC Code\FRC_library.lib'.
I am sorry if this is answered in the post above but I did not understand it if it did. As you may guess I am not a programer myself, I am setting up the laptop for the porgraming team for regionals. These are all apps that I have downloaded of the net, so maybe I need something that FIRST gave me, though I am not sure. Any help is appreciated. |
Re: On compile: "Coff file format for 'ifi_library.o' is out of date."
You should be using:
MPLab v7.2 C18 v2.4 Newer version aren't supported. |
There's more than that..
My problem is our team is limited on the computers we have to develop software. I am one of the mentors and bring my laptop from work in for our team to use in the evenings. For work I use the MPLAB IDE v7.31 and the MPLAB c18 v3.06. The only way to use the current IFI/USFirst library is to unload my office version of MPLAB/C18 and reload the older software.
Can IFI/USFirst build a library for those users that have the new Microchip MPLAB. David Barr Mentor (Programming) Team 141 WOBOT West Ottawa High School |
#7
would it work to create another account (probably administrator) and instal the robotics stuff there?
#9
From my store of "usefull things to remember".
I once read that the MPLAB compiler cannot handle the linking of files whose source path exceeds 62 characters. (Didn't count the length of your path) But almost anything in the C:\... user ... docs folder stream if you've organized it would be banging hard on the limits. Simple solution == move your source directory closer to C:\ ie c:\FirstCode\XYZ |
#10
...just a heads up that this thread was originally posted during the 2006 season -- so the applicability of some or all of this information may (or may not) have changed.
#11
The initial thread issue remains the same today re path length.
the other issues also remain as far as using MPLab v7.2 and C18 v2.4. The decisions about library updates are what they are though. |
#12
The issue is a PIC issue and not an IFI issue... From the readme file of C18 compiler V3.00: Quote:
I had hoped that IFI would offer recompiled libraries but they have not. I would guess it might have something to do with over 1300 teams getting free C18 compiler software from Microchip. Regards, Mike |
| C HELP PLEASE | sglegend11 | Programming | 4 | 14-11-2005 21:35 |
| File Format Conversion Solidworks to Inventor | coreyjon | Inventor | 2 | 21-01-2005 20:11 |
| Error in header file p18f8520.h !!! | RbtGal1351 | Programming | 3 | 17-01-2005 16:03 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| File Sharing and Revision Tracking | Madison | FIRST-related Organizations | 14 | 04-06-2003 18:01 |
