Go to Post Mark McLeod, spreadsheet whisperer - PayneTrain [more]
Unread 07-03-2006, 16:42
HRobotics's Avatar
HRobotics HRobotics is offline
Havergal College Robotics Team
AKA: Tracy, Amanda and Katrina
FTC #0156 (PiRobotics)
HRobotics will become famous soon enoughHRobotics will become famous soon enough
Programming VEX Controller
Hi;
We're having a few problems programming our controller with the VEX easyC (we realise that the VEX season is over, but we're still working on it, so we're still having issues). (We've searched this issue quite a number of times... couldn't find anything... if there are any other threads that deal with this, we'd be grateful for a link.)
So the scenario is: We would like to use 5 motors in our robot. 2 motors will be controlled by 1 joystick that makes it go up-down-left-right (to control the robot). The other 3 will be for the arm.
So the problem is: We want to use 2 motors to move the arm forwards and backwards ; the other, to move the scoop up and down. If we use the arcade (-2 motor) for the arm, we wanted to make the arm go back and forward with the *up arrow* and *down arrow* of the joystick. We wanted to use *right arrow* and *left arrow* for the claw, but when one turns, the joystick goes to the left or right, and that causes both motors to go in reverse. This will cause problems. (I really hope that made sense...)
We'd also like to know if there is a way to program the controller without using the preset functions like arcade or tank. If there isn't, is there an alternate way to address this problem?
Thanks,
HC Robotics (Katherine + Hilary).
PiRobots - We're on FIRE!
Unread 07-03-2006, 19:28
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Programming VEX Controller
you can program the VEX with MPLAB and the mcc18 compiler look around vexrobotics.com and some other vex sites and you should come accross the default code and the IFI Loader you will need
KK4KQO
http://voltair.us
Unread 12-03-2006, 17:34
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You can write directly to the set motor function in EasyC. Just get the data from RX Input assign it to a variable and then play with it as you wish and dump
the value back into the motor.
//Could someone move this to the VEX EasyC forum?
P.S. A64 all the way.
Unread 21-03-2006, 22:23
Jackel148's Avatar
Jackel148 Jackel148 is offline
FTC #0160 (Impulse)
Jackel148 is an unknown quantity at this point
Cool Re: Programming VEX Controller
Originally Posted by HRobotics
Hi;
Thanks,
We were having the same problem you might find it easier if you just put the turning motions or the forward and backward motions on the switch that is on the bottom of the controler...the problem is that the joysticks are two sensative to the other motions as well (such as up and down)
let me know if you need any more help if you want just email me the easy -C from a screen shot and I will look at it for you
but know their are no other presets to get aaround the tank and arcade sorry
I hope this helps
Jackel
Unread 21-03-2006, 23:25
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
          Left Joystick:                           Right Joystick:
           [drive fwd]                               [arm up]
[drive left]<------->[drive right]       [claw open]<------->[claw close]
                v                                       v
           [drive rev]                              [arm down]
Using the joystick as mapped above, try using this code:
#include "Main.h"
void main ( void )
      unsigned char arm; // Create a unsigned char variable called arm
      while ( 1 )
            // The Arcade Drive Code Block
            // Connect The Left Drive Motor to Port 1
            // Connect The Right Drive Motor to Port 2
            Arcade2 ( 1 , 3 , 4 , 1 , 2 , 0 , 0 ) ;
            // The Arm Drive Code
            // Connect the Arm Motors to Ports 3 and 4
            arm = GetRxInput ( 1 , 2 ) ;
            SetPWM ( 3 , arm ) ;
            SetPWM ( 4 , arm ) ;
            // The Claw / Grabber Code
            // Connect the Claw Motor to Port 5
            MotorRcControl ( 1 , 1 , 5 , 0 ) ;
Art Dutra IV
世上无难事,只怕有心人.
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
VEX programming Gene F Programming 14 08-08-2006 22:21
Vex controller - outputs not working jrecht FIRST Tech Challenge 2 06-02-2006 23:26
Vex bot programming Q's BaldwinNYRookie Programming 6 09-10-2005 17:45
Programming Vex Starter Kit To Recieve From Serial Port firetrap FIRST Tech Challenge 0 26-09-2005 17:27
