pic: Dented IFI Wheel
Re: pic: Dented IFI Wheel
Those wheels are trash, They are not even near round as far as where the sprocket hooks in. Whe had to make a lot of mods to the wheels to make them better, but still they are not near perfect. They are to expensive, and take forever to put together.... Our team will not buy again.
I don't think the IFI wheels are trash at all. They are very grippy and very light. They are also exceptionally strong for their weight. This photo is the only example of damage to an IFI wheel that I have seen so far, and the damage appears to be minor.
My team decided to go with holonomic drive this year so we didn't use the IFI wheels, but we certainly would have used them had we gone with a 6WD drivetrain. |
Wow this is one of the first negative posts I have heard about the IFI wheels. I just have a few comments to make about your picture and the IFI wheels all together. 1.) In the picture i can't really tell where the dent is. Do you mean on the edge of it where the picture is a little blurred? If so it looks like you hit something with it. 2.) The IFI wheels are almost indestructable. Even with dented wheels you can still drive. 3.) The IFI wheels shouldn't have taken you to long to put together. I showed a group of high school kids how to put them together and in under 10 minutes they had the IFI wheels put together and the sprockets put on them. And we have yet to have a problem, even with the original IFI wheels that we tested we didn't have a problem with them. 4.) These wheels beat just about anything you can make. They are light, and almost indestructible, what else could you ask for? Did you try different wheels out? Such as to buy another one from IFI to see if it was the batch of wheels that made things so difficult for you? /edit: It took us (team 229) hitting the wheel repeatedly with a hammer to get any significant dents that would disrupt the driving of a robot. I doubt a robot is going to have its wheels hit nearly as hard in competition. |
We must have got a bad batch of them, because all 6 that we got are way out of tolerance. It took about 45 minutes to put each one together, bc the tread material was to short. At first it caused out chain to pop every time, because there was a high and low point from the chain caused by the sprocket holes not being drilled in the center. And I have also herd some horror stories from down south that the bearings tear apart after about a week and a half of use from more than one team….
To expand on what Tim said,
Our experiences were very positive, like they weren't perfect but they were darn good. With what I’ve learned this year I’d use them again in a second, I’d probably change a few things about the way I used them (such as sprocket placement, and hardware used) but we were pleased. Another important point is we fought weight hard core this year, and there is no way Irrational would've ever made weight without the IFI wheels. We have 12 on the robot. 8 in the 8 wheel drive system 4 in the ball lift system Chalk up one to a statisfied customer, Chris C. Team 229 |
#7
The designer of these wheels visited St. Louis back in December, serving as a technical advisor for our FVC demonstration event. He left me a sample 6 inch x 1.5 inch IFI wheel.
A few minutes ago I took that sample down to the CMM that we use to check parts here at Emerson's motor tech center. The results showed that the six hole pattern intended for mounting sprockets is concentric to the bearing hole within 0.004". Each of the sprocket mount holes was 0.197-0.198 diameter (very nearly 5 millimeters). I'd conclude that the ideal sprocket screw size would be #10, or M5 if you wanted to use metric fasteners. Off center sprocket mounting could result from using smaller fasteners such as #8. Of course, my CMM results are from a single sample. Close inspection of the holes indicates to me that they were punched, not drilled or bored; from this I guess that the sample was made using the punch tool that IFI subsequently used to make production parts. |
#8
My only real concern is with the press nuts; I realize that that's a concession to cheap manufacture, but I really hate the things. (They can, if overtightened, strip out.) |
#9
#10
I really like the new IFI wheels. It would be great if they could lower the price by about half by next year. They were new and expensive this year but maybe by next year they can produce them in enough volume that the price will come down. I would dearly love to see these included in the KoP next year. Like I mentioned before in another thread, it would really be nice if FIRST would ditch the wheelchair wheels next year and include vouchers or something for 2 or 4 IFI wheels in whatever size you want. Sort of like they do with Bimba for the three air cylinders. If you want more than the 2 or 4 included in the KoP then you can buy them. |
#11
Oh Jeff... always being such an aggressive driver... after I saw the thread title I figured it was you. I didn't even look at your name under the title. Team 151 slammed into the lexan on the ramp and they bent a peice of their angle stock. I don't have pictures, but it was scary seeing them carrying it around. |
#12
That picture was the only problem that we've had with these wheels at competition. Haha and Dan, you're right, I am sometimes too aggressive for my own good, but we were able to outpush any robot out there and we're very pleased with the wheels. We still were able to drive the robot and it didn't affect its performance. The dent is around the middle of the picture, where there is a slight blur. Sorry for it being of bad quality, it was from my camera phone
We had another problem before this though and it was partially due to the chain on the sprockets being too tight. It would squeeze the sprocket off alignment, and so we fixed that by using the 3/8" ID bearings since they are the same OD as the hole in the sprocket and so it is supported that way. Adds some weight but fixed the problem. All in all, we're more than pleased with the IFI wheels and chances are, we'll use them in the future. |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| pic: Planetary Wheel - Exploded View 4 | Matt Krass | Extra Discussion | 5 | 23-06-2005 23:56 |
| pic: Wheel got dented during a match | davelu | Robot Showcase | 24 | 05-04-2005 23:58 |
| pic: 296's Tri-Star Wheel | CD47-Bot | Robot Showcase | 23 | 16-02-2004 11:27 |
| pic: da wheel | CD47-Bot | Robot Showcase | 11 | 08-02-2004 22:04 |
