Go to Post Many students I have met will insist that nothing is better than FIRST robotics. And most people would agree that a ham sandwich is better than nothing. So does it logically follow that a ham sandwich is better than FIRST robotics? - tsaksa [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 09-03-2006, 14:22
Labview dashboard and multiple variables
Is it possible to have a graph that displays two different variables? I'd like to display one of the userbyte variables on top of another.
I also have a case where I'd like to display 2 bytes of data that is sent in two seperate bytes in the same variable. If I can figure out how to access two of the bytes at the same time, I could mathematically combine them and display the result.
Unread 10-03-2006, 11:42
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Labview dashboard and multiple variables
Joe,
I've attached an example VI that may help illustrate the capabilities. In the VI, the run-time of the VI is used to calculate sine and cosine outputs (ie two different values similar to the two userbytes that you want to plot). You'll notice that there are 3 different graph types used in the example - waveform chart, waveform graph and XY graph. They're very similar but there are subtle differences which can become useful to exploit in certain applications.
Waveform charts are typically used to append single data points (of "N" different variables if desired) to a rolling graph. I don't think that the x-axis is very flexible - all samples are plotted vs "sample number" and not "time". I don't think that the x-axis can be changed from "unit" demarcations.
Waveform graphs are typically used to plot arrays of data with fixed x-axis demarcations (eg 25ms marks as in the example).
XY graphs are typically used to plot arrays vs. "each other".
LabVIEW also supports a variety of more elaborate graphing functions. My best advice - have fun using trial and error and ALWAYS keep the Context Help window open (Help -> Show Context Help or press the big ? mark button on the toolbar).
Good Luck!
Russ
Unread 15-03-2006, 21:55
Thanks With the example and descriptions you gave, I'm able to add the data I want to the dashboard.
Labview Video Tutorial? Dashboard Chris_Elston National Instruments LabVIEW and Data Acquisition 21 25-01-2008 00:29
Dashboard Port Decoder whytheheckme Control System 39 06-03-2006 18:14
LabView Dashboard brummer_13 LabView and Data Acquisition 7 08-02-2006 21:43
