pic: IMG_4104.JPG
Re: pic: IMG_4104.JPG
First off, NICE JOB
. Second, How did you do that to the poor thing? I hope you found a replacement or something. Good luck. |
It fell off at some point in the match and most likely got run over. and yes 470 loaned us their camera for the rest of the regional.
OH I think Im going to be sick!
You knocked your robot's eye out! ![]() |
Ohh the
Laffy Taffy stock just plunged 87% !!!
#8
Ours fell off our camera as well, into the gearbox. Afterwards it looked fine, but all the images we got from it were extremely bad. And it refused to work, swapped it out with the 2005 camera lens, and it worked. Afterwards we took some zipties, and put it through both sides of the mount, pulled it tight, and made sure it could not fall off
#9
That happened to us, only it was irreplacable. I'm not sure what happened, all I know that it had to be taken off.
I was completely fine with that anyway cause we were overweight until we took the camera off. |
#10
To any other teams that experience this problem; zip tie the camera lens on. We had that part of the camera fly off our rotator back during build season, so we zip tied it on Friday morning, never had one issue the whole Regional with it. If your using the mount assembly given in the kit, you can easily wrap a zip tie vertically around the camera and back mounting plate without affecting the camera.
#11
At buckeye our team used last years suggested camera case ( A black plastic case from radioshack) with a hole drilled for lenses and pwm connections, Worked out great. Ontop of that we used a faceshield with a custom made bracket to protect our camera from rouge poof balls. Turns out we got flipped camera down in one of our matches and if we wouldnet have made the custom bracket so well, we would have lost the camera. All we ended up needing was some bending and we were good to go!
Unfortunitally, we had some pretty odd issues with our camera not even receving data. To me it looked like there was a flakey connection somewhere in either the camera or the ttl board and no ammount of fiddling fixed it ![]() Last edited by Rombus : 12-03-2006 at 02:08. |
#13
Im going to work on learning microchip C and PIC Processors this summer to be sure i can cross over to progamming when things like this happen. Do you happen to have a link talking about this so i can look it over when im thinking clear again? |
| pic: 1018 - Pic 5 - TWINS ? ... (or mirrors ?) | Stu Bloom | Robot Showcase | 7 | 18-02-2006 15:17 |
| pic: 1018 - Pic 4 - Welded Chassis | Stu Bloom | Robot Showcase | 17 | 03-02-2006 21:36 |
| pic: River Rage 9 pic | JohnBoucher | Extra Discussion | 2 | 30-10-2005 14:43 |
| Using a computer to control the pic | mikesown | Programming | 6 | 13-09-2005 19:13 |
