Go to Post It seems ironic to me that a robotics competition would come down to human error, which is precisely what the field of robotics attempts to prevent. - David8696 [more]
Unread 13-03-2006, 12:35
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Analog Inputs
If we had an analog input device hooked up to Analog Input Port 1, what would the value rc_ana_in01 represent? Is it the voltage? Or possibly (Voltage * 1024 / 5)?
Unread 13-03-2006, 12:36
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: Analog Inputs
Resistance is usally the value it looks at. I have minimal FIRST electircal experiance but normally this is whats looked at with analog.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 13-03-2006, 12:42
AKA: Dr. Brooks
no team (WRRF)
Re: Analog Inputs
rc_ana_in01 is a constant that you pass to GetAnalogValue in order
to read the corresponding analog input.
For example:
int analogvaluefrominput01;
analogvaluefrominput01 = GetAnalogValue(rc_ana_in01);
The resulting value stored in the int variable has the range 0 to 1023
0 corresponds to roughly zero volts, and 1023 corresponds to roughly
5 volts. Your equation reflects that.
Edit: The analog inputs on the RC look at voltage. When a POT is
hooked up to one these inputs it is wired as a voltage divider for a
5 volt supply. The analog inputs on the OI have a different range,
0 to 255(254), and are set up to jump to 127 in the event that 0 volts is
applied (or the circuit opens), for safety reasons.
Eugene
Unread 13-03-2006, 12:58
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Analog Inputs
There is an upper and lower threshold to these voltages. I don't remember exactly where they are but it is significantly different than 0 and 5V. Over the Upper Threshold you will get 1023. I think you get 0 below the Lower Threshold. Make sure you center any pots you are using so that the entire Range of Motion is in the significant voltage range.
Robot Inspector
Unread 13-03-2006, 13:08
bush's Avatar
AKA: Aaron
Re: Analog Inputs
ahh thanks I understand now
So for example...
The dual-axis accelerometer supplied in the kit has a sensitivity of 290mV per g (acceleration due to gravity) and a range of +/- 2g. So the accelerometer reports voltages in the range of 1.92 - 3.08, and Get_Analog_Value(rc_ana_in01) would return values in the range from 393 - 631. Then I can convert that number into units of g with...
(Get_Analog_Value(rc_ana_in01) - 512) * 5.0 / 1024 / 0.290
Unread 13-03-2006, 17:49
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Re: Analog Inputs
Originally Posted by 2005 Full-Size Robot Controller Reference Guide
Any sensor which outputs a variable 0-5V signal may be read with 10-bit resolution on these inputs.
The correct function spelling is Get_Analog_Value() and it is defined in ifi_utilities.c
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Dashboard with analog and dig inputs Andrew Schreiber National Instruments LabVIEW and Data Acquisition 1 13-02-2006 22:48
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
Failing analog inputs? Phasmatis568 Control System 5 22-01-2004 13:28
Serious Controller Ideas archiver 1999 28 23-06-2002 23:01
