CMU Cam Freeze-ups
On our team, we have successfully made the camera track the FIRST target, but when we start using our drivetrain, then the camera freezes up and cannot be "unfroze" with any software. Does anyone have any suggestions? Any help would be greatly appreciated!
Re: CMU Cam Freeze-ups
The obvious suspect is the sudden drop in voltage.
We've had luck with reititialize the camera whenever we don't receive T-packets for a couple of cycles, but we do it repeatedly until the camera responds, with a proper delay to allow the camera extra time to complete initialization. It also sometimes takes care of the case where the lock light stays on even with no target. We test it by unplugging the camera. Last edited by Mark McLeod : 17-03-2006 at 12:36. |
I'll run that by our mentors and probably go through the system with a multimeter. We run 2 minibikes on the shooters, 4 small CIM's in our transmissions, and 2 Fischer Price's in our ball Rollers. This is a lot of volts, and we may be drawing from the back-up battery
Thanks. |
| CMU Cam + Lab view Question | Dillon Compton | Programming | 6 | 06-02-2006 12:02 |
| CMU Cam prosseser running hot | kjhobin | Programming | 4 | 10-01-2006 21:57 |
| Video of the (not so) humble beginnings of the CMU cam. | Elgin Clock | Programming | 0 | 29-03-2005 21:31 |
| CMU Cam GUI | Arc736UV | Programming | 2 | 15-03-2005 19:26 |
| CMU cam and Linux? | scitobor 617 | Programming | 2 | 30-01-2005 23:02 |
