Go to Post used to find BBQ(Blue Banner Quotient) and SAUCE(Sextuple Advancement Uniform Counting Era)[URL="http://bbqfirst.x10host.com/index.php"]bbqfirst.x10host.com[/URL] Happy BBQing! - Beaker [more]
Unread 30-03-2006, 19:44
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
NEED HELP NOW!!!! TRIGGERS DON'T WORK
All of our triggers and buttons on the joysticks don't work, even with the default code. What can we do?
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 30-03-2006, 19:58
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: NEED HELP NOW!!!! TRIGGERS DON'T WORK
Do the analog outputs (axes) work or is the entire stick dead? What happened prior to the controls breaking? Also, have you tested the stick in another port (as well as tested that port with a different joystick)? We had a problem a few years back with a malfunctioning OI port, and didn't think to bother testing it for a few days!
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 30-03-2006, 20:02
Ken Leedle Ken Leedle is offline
College Student
FRC #0706 (CyberHawks)
Ken Leedle will become famous soon enoughKen Leedle will become famous soon enough
If all the hardware is working, you may have multiple definitions for whatever you want the trigger to control, esp if it is a pwm output. Comment out the default definition.
Unread 30-03-2006, 21:22
Revolverx7's Avatar
Revolverx7 Revolverx7 is offline
Ninja
AKA: Sanders
Team Role: Driver
Revolverx7 is on a distinguished road
Send a message via AIM to Revolverx7
How many sticks are we talking about? 1 or 2? If one, try swaping it out for an alternate. Some of the newer joysticks like to just die on you. But if its both sticks refer to your programming. Thats not too much help, but as a driver thats about all I do to troubleshoot fixes like that.
2006 SBPLI Regional Champions (with 271 & 870)
2006 UTC Finalist (with 181 & 585)
2005 SPBLI Regional Chairmans Award
2005 SBPLI Regional Champions
2005 Philly Regional Finalists
Unread 30-03-2006, 21:31
Reading your description at face value, here's what I'd do: take apart the joystick, trace the ground wire, find the spot where it's broken, and repair it.
Unread 31-03-2006, 15:44
Re: Joystick Triggers No Longer Work
The problem was a bad OI. Ports 1 and 3 don't work but 3 and 4 did. We just got last years board hooked up.
Unread 31-03-2006, 16:06
I had a feeling that could have been the problem. It sounded very familiar. Glad to hear that it has been worked out.
Were the entire ports malfunctioning or just the digital inputs? If you ever needed to utilize those ports again and the analog inputs were still functioning (so long as you didn't need all the analogs) you could always remap some of the digital switches to use the analog inputs. It's a relatively painless process and it is a good workaround if necessary. I know I've had to do this a few times: once because of that broken port issue, and the rest just to use additional controls; I'm sure many, many people have dealt with the same thing in the past.
Unread 04-04-2006, 13:58
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Check the Disable switch bank on the bottom of the OI.. I suspect someone was playing with the switches, which would cause exactly what you are talking about.
They should all be in the same position, but I'm not sure which way.
What Artist Influence You? Koko Ed Chit-Chat 12 01-12-2006 11:33
speeding up the work on 3ds MAX (and then some) Nimmy 3D Animation and Competition 1 01-02-2006 14:57
Major CMUcam issues - LabView app won't work, very low-quality picture scottmso Programming 5 19-01-2006 17:51
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
When to leave that first tech job? Morenoh149 Career 4 07-10-2005 00:40
