Go to Post Though, of course, if the old one you like is shot, then you can just beat your new one with a hammer until it works the way you want. - Kevin Sevcik [more]
Unread 03-04-2006, 04:39
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Pic: Easy to make mecanums..
Okay, as an offseason project, part of 1072 is making a mecanum drive.
first part (and probably the hardest) is the wheel.
here's our scheme for making one.. we'll make at least one over this break (its spring break for us) and report back how it is.. but if you see any glaring problems, please post asap.
Tools -
A Mill (Bridgeport in our case)
1/4 in end mill / drill bit
1 in , 3/4 shank end mill
Clamp set
Indicator
Vise
Edge finder
Materials -
3/4 plate 6 in x 36 in
Lab-stops (Mcmaster - 9545K15)
Generic 2 3/4, 1/4-20 bolts
1/4-20 nuts
retaining rings.
First, Take the plate, cut into 6 plates of 6 in x 6 in.
Next, bring to our friendly machinist, and have him turn the plate into the following pattern..
http://i27.photobucket.com/albums/c1...3456/Part1.png
Now, take back to the brigeport, tilt the head 45 degrees, and true the vise.
Then after we have that, we can just vise the plate using the octagon.. that will ensure true-ness on one plane (ie the y is now true) and then find the center of the octagon, and then use a 1 in endmill, then a 1/4 in end mill through to get..
http://i27.photobucket.com/albums/c1...3456/Part2.png
Then, since this form is quite awkward, after tramming the head to 90, we make some ornamental cuts.
http://i27.photobucket.com/albums/c1...3456/part3.png
Now there's the hub, the rollers should be equally easy. originally, we were planning on begging for someone with cnc lathe to cut us this profile..
http://i27.photobucket.com/albums/c1...3456/Part4.png
But, our student mentor realized that a lab stop, bored with a .25 in hole would be nearly identical in terms of circularity (the one and maybe even only key measure of wheel performance)
here's comparison of theoretical optical versus lab stops
http://i27.photobucket.com/albums/c1...3456/Part5.png
Finally, it should look like..
http://i27.photobucket.com/albums/c1...3456/Final.png
So. Any suggestions, comments, concerns?
Unread 03-04-2006, 12:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Pic: Easy to make mecanums..
Looks like a plan. It's clear you've thought quite a bit about it. Good luck with making it. I'd like to see the finished product!
Unread 04-04-2006, 20:22
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
So i thought about this for a lil while and thought of something. My expeirence with lab stop it that it was a very soft compound rubber that seemed to peel and cut very easily. I think i wouldnt be durable enough for driving around on carpet and pushing other bots around.
MechWarriors 573
Unread 04-04-2006, 20:28
Andrew Blair's Avatar
FRC #0306 (CRT)
Looks good, but how I hate to see all that Al burned through! Seems pretty possible with no CNC stuff. Though a rotary indexer is a must.
-Sir Francis Bacon
-Albert Einstein
Unread 04-04-2006, 20:34
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
It's interesting to read others' ideas for producing these sorts of wheels with minimal headaches. I, too, have been giving it some thought lately as a potential off-season project for our team and was trying to design a wheel that could be made using what we have available -- a 3 axis CNC mill, drill press and lathe.
Forgive my lack of step-by-step illustrations
--Madison--
...down at the Ozdust!
Unread 04-04-2006, 21:29
AKA: Bill Hancock
Ok o searched this one and i couldnt find anything difinative. What is the difference between omni wheels and mercanum wheels. i know the power used i different depending on the direction moving but i thought i read somewhere the it is hard to push bots with mercanum wheels but easy with omni wheels.
any help i appreciated thanks
Bill
MechWarriors 573
Unread 05-04-2006, 00:08
The difference is the angle of the outer rollers. Omni wheels have their rollers round sides facing at 90 degrees to the wheel's roundness. Mecanums have their rollers at about 45 degrees (though this is variable). If a team has mecanums, you will have a harder time pushing them (due to the angled rollers and the power--four motors available versus two at any given time for omni's). However, it is still possible to push mecanums around, it's just a little harder.
Unread 05-04-2006, 02:47
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Two quick comments on the first design-
With the support for the rollers in the center, they may not turn as efficiently.(not too big of an issue)
Having the rollers positioned like that will make it easier to bend the supports(leverage and all that) if they get hit. Protect them well.
Team 675-Alumni
Near Chaos Robotics
Unread 06-04-2006, 02:07
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Horay for lab stops and ghetto-ness. Hey, if it works, we'll let you guys know. If it doesnt, we'll make it work, and let you know
Unread 07-04-2006, 09:56
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
I almost wonder if the design by NeilR (http://www.chiefdelphi.com/forums/sh...t=mecanum+sell half way down) wouldn't be easier to make.
http://www.chiefdelphi.com/forums/at...achmentid=3745
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 07-04-2006, 12:59
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
I cant see your pictures while im here at work but from your description your manufacture method is very similar to the latest i've come up with. the term "easy to make" has to be viewed very realitively. because as far as the basic wheel goes there's no real easy wayt to make it without the right tools.
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
How to pass your inspection at Nationals, the EASY way Matt Reiland Championship Event 0 04-04-2003 18:39
Please help make the Nationals in Houston AWESOME ... You be the Tournament Director Natchez General Forum 42 13-12-2002 18:50
5 points I make..(and a little excess) archiver 1999 7 23-06-2002 22:18
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
