Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 12-04-2006, 16:01
M-A-T's Avatar
M-A-T M-A-T is offline
AKA: Mat W.
FRC #0836 (Robobees)
M-A-T is an unknown quantity at this point
Send a message via AIM to M-A-T
What to do now
OK so I've been on my team(836 wot wot) for 3 years and I'm graduating this year and has said as it sounds I'm gonna miss it, other than maybe coming and volunteering in regionals and so on, what other ways are there to stay involved with first, or is there other related programs that there are college teams for.
first my antidrug, next to god, latin,halo 2 and women, of course
Unread 12-04-2006, 16:08
Re: What to do now
Depending on the engineering degree you are persuing, there are many college level engineering design contests / challenges / projects that you can be a part of.
In all honesty, the stuff you will get to work on in college will make FIRST robots looks like childs play!
Some of the projects Ive seen at RIT in the last few years:
Off-road Go-cart like design and race (international contest)
Autonomous aircraft design contest
Automomous submarine, project that monitors the water quality in lake Ontario
Micro aircraft used by forrest rangers
Micro jet turbine engines
as a matter of fact, FIRST is somewhat of a spin-off of the senior mechanical engineering design contest that Dr Flowers held in his class at MIT - they use to show the contest every year on PBS (seems like a long time ago).
Unread 12-04-2006, 16:42
Billfred's Avatar
Billfred Billfred is offline
Re: What to do now
Obligatory warning: School comes first. If you have to choose between doing homework and going to a build season meeting, do the homework. Don't skip classes unless you are fully aware of the consequences and have measures to reduce their impact.
You didn't mention where you're going to school, but look up the listing of teams (don't forget FVC and FLL) around where you'll be going and see if they're in need of some mentors. (You'll want to take transportation into consideration as well in this--I can drive to most teams in town blindfolded, but that's because I have a car. If I had to take the bus, I'd be functionally out of luck.)
Of course, it might be good (especially for your freshman year) to take a year off of a team and just volunteer at an event if one is within range. (Looking back, I might've been better served by doing so.) Look at VIMS on usfirst.org for a list of events, and try to make contact with a member of the committee behind that event. The latter part isn't really required, but it can't hurt.
Good luck!
Unread 12-04-2006, 19:06
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
Re: What to do now
Good luck!
Or if your like me, living at home and going to college, you could schedule your classes kinda around your local robotics team. Which is not alway easy to do. Also I've got to learn to step back even more next year than what I did this year. Like instead of putting the kit transmission together myself, give all of the parts to one or more students, with the instructions, and make them put it together. I always learning from my mistakes.
Unread 12-04-2006, 20:03
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Re: What to do now
This is what I'm going to do next year. I'm not going to like some other alumni and come back and try to take over the team. Like our class of 2005 was.(love you guys anyway) I hope to help the 2006-2007 robotics team learn.
Thats what FIRST is all about!!! Not control FREAKS !!!
Unread 12-04-2006, 19:11
Andy Grady Andy Grady is offline
I'm done being quiet!
FRC #0131
Rookie Year: 1995
Andy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond repute
Send a message via AIM to Andy Grady
Re: What to do now
Boyyyy is Billfred right on this one!
While the 5 year associates degree program may sound fairly glorious, I assure you its not quite the picnic that its made up to be!
My advice to you and every other high school student making the transition to college...volunteer, volunteer, volunteer.
The beauty of being a volunteer at an FRC event is that you get to see how that magic that just suddenly appears when you are a student, comes to life behind the scenes. Not to mention food...lots and lots of food! Good food! If nothing else...do it for the food.
If you do decide to go the team route in college...remember FIRST is a massive undertaking, make sure you plan your time out strongly and stick to the schedule. All it takes is for one or two miscues and your college experience becomes alot more expensive as a result of this wonderful program we call FIRST.
If you do it right...the experience of moving from student to mentor can be amazing. Just be smart about it.
-Andy Grady
Unread 12-04-2006, 19:56
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: What to do now
-Andy Grady
Yes, I volunteered this year and it was a great experience! I suggest it to you and everyone. Its a lot different than building and competing with your robot, but it is still a lot of fun. There is a lot of work that goes into putting together the regionals I suggest that you help out with that. A lot of the time the dates for regionals fall on spring break for colleges. You can focus on school work for the year and then on your break volunteer at one or two local competitions.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 12-04-2006, 17:27
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Reject False Icons
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Re: What to do now
PODCAST!
Well, I'm lucky there, but it won't hit you too much till around the regionals, then you'll loose your mind. Get a VEX kit and have fun. Oh, and post lots and lots on CD.
Steal back your future
Unread 12-04-2006, 18:23
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Re: What to do now
You could always just start a new team like Dean says. Yes, I realize that is for those who have free time.
Unread 12-04-2006, 19:03
GoSparx's Avatar
GoSparx GoSparx is offline
AKA: Big D
FRC #1126 (SparX)
GoSparx is just really niceGoSparx is just really niceGoSparx is just really niceGoSparx is just really niceGoSparx is just really nice
Re: What to do now
Remember what FIRST is all about. You don't need to JUST help out on the team, at a regional or the Nationals. (Although I can say from experience it is a lot of fun) FIRST isn't just about building robots. Go out and help out and a homeless shelter, help out in your community and yes of course for the robots sake please try and find other teams to help out on or even be a mentor. I hate to sound old(because trust me i'm not), but when im mentoring these high school kids on the team in the workshop or anywhere, I get a great feeling of joy inside. So please do something that is FIRST like and of course, ALWAYS HAVE FUN!!!!!!!
"Winning is an Outcome"
2003-2008 Match record 152-81-1
Trips to Einstein - 2 (04' + 06")
'03, '04, '08 Buckeye Champs, '07 Finalists
'06 Finger Lakes Champs, '08 Finalists
'06 Galileo Division Champs
'04 Newton Division Champs
'08 Buckeye Motorola Quality Award
'07 Buckeye General Motors Industrial Design Award
'06, '07 Finger Lakes Rockwell Automation Innovation in Control Award
'05 Buckeye RadioShack Inovation in Control award
2-2009 J+J Gracious Professionalism Awards(FLR+GTR) & Xerox Creativity Award(GTR)
