Go to Post FIRST robotics: Not just for nerds. - Koko Ed [more]
Unread 16-04-2006, 22:58
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
What to do with pneumatics in the off-season
Make ice cream.
http://media.putfile.com/Pneumatics
Unread 16-04-2006, 23:13
Billfred's Avatar
Billfred Billfred is offline
Re: What to do with pneumatics in the off-season
That totally gave me an idea for an off-season project for 1293.
Can you give us some more specifics on the setup? Surely those aren't powered by the KOP compressor.
Unread 16-04-2006, 23:31
I was wondering if they used the RC to control the valves.
We are such nerds.
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
How did you do the timing?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 17-04-2006, 12:17
ICE MAN's Avatar
ICE MAN ICE MAN is offline
ICE MAN
AKA: John Cory Brown
FRC #0832 (Chimera)
ICE MAN is an unknown quantity at this point
Send a message via AIM to ICE MAN
one of our projects is to make a ultimate Nerf shooter that uses the pneumatics to charge the gun instead of human pumping. One cool project that i saw was two years ago at nats, a team made a pneumatic wolverine blades that were controlled by a pneumatic back pack. the guy would occasionally raise his right arm and shoot the blades in and out. it was totally wicked.
In life, if what we want and what we get isnt what we expected, then thats life, because we cant always get what we want and what we get is never what we expected.
This is our teams offical website, enjoy:http://www.angelfire.com/droid/roswellrobotics/
Unread 17-04-2006, 12:50
Andrew Blair's Avatar
FRC #0306 (CRT)
If you look carefully at the back of the cylinders, you'll see what I imagine to be the magnetic reed switches supplied with certain cylinders. I think that as the cylinder trips the switch, you switch the pressure on the cylinders.
-Sir Francis Bacon
-Albert Einstein
Unread 17-04-2006, 17:54
FRC #3974
That's correct, we used the magnetic pistons with reed switches. The switches are wired directly to the solenoid valves without going through a controller. It's powered off a small shop air compressor. The two 12" X 1 1/2" pistons would be way too much for the kit compressor, at least at a speed that would keep the ice cream from icing up.
Unread 30-04-2006, 15:40
Umm Errr...
Well last night, i built a C02 powered potato cannon based off a Quick Release valve from a bus air brake system.
I like the ice cream maker. I want some ice cream right now.
1139 Alumni
Unread 30-04-2006, 18:29
in between teams
AKA: Luke Van Oort
At some point I may convince my team to make a hardcore teeshirt cannon. 6 Compressors, twelve Clippards... watch out! I'm thinking about trying to make a supersonic pellet gun, but it would need insanely high pressures, well above what the kit parts can take. (mmm, can you say 1Kpsi?)
Team 1219: 2009 - Mentor
pneumatics for 2006 competition? Joobacca Pneumatics 10 21-01-2006 23:14
Reflection 2005 Season Bcahn836 General Forum 23 26-04-2005 22:33
A report on off season competitions Ken Leung Off-Season Events 2 17-10-2003 13:30
No Pneumatics This Season?? BBFIRSTCHICK Rumor Mill 9 18-01-2003 13:21
