Go to Post Pursue your passion whatever that may be and do not fault another for pursuing theirs. - Mr. Van [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 23-04-2006, 23:20
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Palm os scouting
I recently purchased a Sony clie on ebay and was thinking "hmmmm, how can i use this at nationals". All i could think of was making a list of all our match times but then i got a brilliant idea (I'm probably not the first to think of this). So i searched the Internet and finally found a database creation program for the Palm OS, it's not very intuitive so you'll have to read the tutorial. It's not very hard to use and once you define certain variables (IE. shooter, dumper, etc.). you can find it *HERE*.you need a palm device with at least palm Os 3.0 which shouldn't be a problem. My only problem with this program is that you can only use the search function for the second column of information, so in the first column i put in if the robot is a shooter, dumper, or both, and i put their team # in the second column. That way i can search for their team number rather then scroll through all the shooters.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
[IMG] code is Off
Scouting Made Easy - Announcing the FIRST Scouting Network Adam Richards Scouting 24 17-11-2007 14:58
Scouting using palm pilots Matt Goulart Scouting 1 10-04-2005 20:07
Muti-Team Scouting System at Midwest Emil General Forum 17 23-03-2005 16:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
ThinkDB palm scouting Jeff Rodriguez Scouting 1 16-04-2002 20:10
