Go to Post [In FIRST]...Arab and Israeli students speak on the same level, because they are alliance partners. - Tottanka [more]
Unread 01-05-2006, 00:58
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Bending Metal
What's the easiest way to go about bending the metal as close to 90 degrees as possible? I tried a vice but... well... that didn't turn out too well.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 01-05-2006, 01:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Bending Metal
What is the material, size, and thickness?
Unread 01-05-2006, 01:15
Billfred's Avatar
Billfred Billfred is offline
Re: Bending Metal
Judging that it's in the FVC forum, I reckon that it's the bar that comes in the kit.
I read a trick in Make: Magazine about bending metal. They suggested two pieces of angle iron clamped together, one of them being at the edge of a workbench or table. With the two sides clamped together, you can bend the metal to your liking. (And the verticalness of angle iron makes the whole 90-degrees thing pretty simple.)
Hope it helps!
[OCCRA]: Bending Sheet Metal troy_573 OCCRA Q&A 1 19-09-2005 22:27
Rules on metal casters stevo2k Rules/Strategy 16 08-02-2005 14:16
Tetra connectors metal or plastic? sanddrag Technical Discussion 10 10-01-2005 22:38
Is this a valid technique? (Color application to metal) Elgin Clock Technical Discussion 8 09-06-2004 21:33
