Go to Post Such is life in the fast-paced, laugh-in-the-face-of-adversity, never-let-them-see-you-sweat, sometimes-you're-the-windshield-sometimes-you're-the-bug world of FIRST Robotics! - Sean Schuff [more]
Unread 27-05-2006, 15:44
Best Available Data
FRC #1778 (Chill Out!)
.mov or .swf to .DV utility?
Okay, the other day I was working on a movie for school and decided to make some intros with Flash. I did and exported them as .movs. Then I copied them over onto my Mac Laptop and tried to import them with iMovie. When I did, it didn't recognize the video, and after a few searches I found that iMovie only imports stuff if it is a .dv stream (whatever that means). Apparently it is an easy process with Quicktime Pro, but I don't have access to that. So does anyone know of a free .mov to .dv converter?
Also I found a video editor for Linux called Cinelerra which looks like it could do it. But the installation process looks rather involved, and I'm not very good at that kind of thing. Does anyone else have experience with it? I'd feel better trying to install it if I knew that it worked well.
Unread 27-05-2006, 16:28
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: .mov or .swf to .DV utility?
MPEG Streamclip should be able to do it.
http://www.macupdate.com/info.php/id/15466
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 27-05-2006, 16:54
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
Which version of iMovie are you using?
Are you using the menu system to import?
The older versions of iMovie would sometimes not import items using the menus, but there are two possible workarounds.
1) Drag the icon of the video directly to your iMovie pallette.
2) With iMovie closed, drag a copy of the video into the iMovie folder holding your video clips. When you restart iMovie, it will tell you there are additional items in the folder and ask if you want them added.
One possible shareware application is ffmpegx which I use when QTPro has difficulty with something.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Looking for a good file utility RIgnazio IT / Communications 1 20-10-2005 19:06
AVI,MOV files? jason_931 3D Animation and Competition 7 20-02-2005 14:13
.mov to .avi Jeff Rodriguez Chit-Chat 8 28-12-2002 02:28
QuickTime or .MOV to AVI or MPEG archiver 2001 2 24-06-2002 02:00
