pic: How do you put an encoder on the FP Gearbox?
Re: pic: How do you put an encoder on the FP Gearbox?
Since you had to cut the gearcase anyway, wouldn't it have been easier to mount a geartooth sensor near the motor pinion and just measure the electrical frequency of its signal? Or was the challenge specifically to do the job with a Vex encoder? |
EDIT: Oops, I guess I didn't read the post carefully enough. Last edited by sanddrag : 06-06-2006 at 14:07. |
But maybe JV was asked to use a Vex encoder for some reason? |
This was a "quick and dirty with what we have on hand" project.
I had plenty of Vex encoders on hand. ![]() My first idea was to attach some retro-reflective tape to the output, and use a banner sensor to count pulses. This would have been the zero-effort approach, and I think they decided it wouldn't annoy me enough, so they wouldn't let me do it. During this project I relearned to hate the FP gearbox (specifically the grease they use inside it). JV |
What is the accuracy? how fast can it track without going mad?
#9
Is that a bracket to support the shaft on the other end or is that just a collar visible on the end of the shaft?
#10
The great JVN does it again. Good looking piece of work there John looks promising. Very cool and exciting good luck with that. I am sure it will help FIRST in some way with the motor specs of the Fisher price motor.
-Drew |
#11
Accuracy -
It measures 1/528 revolution of the gearbox output. It can handle up to 1700 pulses/sec, but will see 1233 pulses/sec in regular usage. There is no opposite supporting bracket; that is just a shaft collar shown in the picture. JV |
#12
So, do the VEX gears mesh with that specific stage of the F-P gearbox? I haven't compared the pitches of each specific stage recently...
However, I can already envision a better use of this, which is to mechanically couple the F-P motor directly onto a existing VEX-bot. (I know the electrical add a couple more components.) Well done, shall we keep our eyes out for a whitepaper? (j/k John!) BEN |
| how do i put the picture next to my avatar????? | call_me_Angles | CD Forum Support | 1 | 18-02-2006 10:17 |
| how to wire the new two motor gearbox | Vince lau | Electrical | 10 | 14-02-2005 07:30 |
| How to put Inventor pics on the web | Andrew Schuetze | Inventor | 7 | 05-01-2005 13:59 |
| how to add steps in the provided encoder program for the edu | Zaramel2002 | Programming | 3 | 11-02-2004 08:35 |
| How much time do you put into building your robot | Wayne Doenges | General Forum | 16 | 29-01-2002 19:30 |
