Hi guys, I've got something new. I've posted a link to the website that my video is on. I just entered it into a contest and I wan't to know how good (or bad) it is. Download it, don't view it off the website because it stretches the video a bit and it screws things up.
PS It sounds terrible in surround sound. alas, I don't have surround sound so I can;t listen to it and fix it. It also sounds a litle metallic because of the compression. Tell me what you think! ![]() |
Re: New video I want an opinion on
Where is the link? |
sorry about that, heres the link:http://www.acidplanet.com/artist.asp?PID=814551&T=294 If the link doesn't work, search for "acoustic rhythms" as the title or "crazy mixer" As my artist name. (I usually put my music on this account but I found I could put my video's on it too) |
Looks good but I have one nitpick: The bass strings should get lower in pitch when they're shorter, not longer. Lengthening the string will only lower the pitch if the tension stays constant (ie a guitar or violin). This appears to be working more like a stretched rubberband. Other than that tho, it's really awsome!
Wow that is really cool....how long did that take to make?
I like it. I love animations of things that dont exist in the real world - esp when you create new things, like new musical instruments.
How easy would it be to change the view point of the camera? The camera seems pretty static, only changes a few times. It would be more interesting if you zoomed in, maybe 25% of the time, synched with the music. Its hard to see much detail from the wide angle view. |
#7
thats sweet nice music and animation. btw what program did you use?
#8
Depending on what the string is made of you wouldn't need to pull it very far to double its pitch, but if you are fretting the string then twice the length gives half the pitch. That appears to be the relationship in the video. |
#9
am i stupid or misunderstanding? If the tension in the string is constant, then a longer string will be lower than a short one. I play bass guitar, and i know that if you play an open string (no fingers on the frets) it will be lower than when my fingers are on the 5th fret, which is lower than the 10th fret. this is why those squealing guitar solos are played way up the neck by the body. shorter string = higher pitch. |
#10
It appears as if the string is being stretched and relieved, rather than being fretted. Last edited by Dan Petrovic : 14-06-2006 at 19:51. |
#11
Man! You guys are quick!
The main thing seems to be with the strings. The idea was that the strings were to be pinched at one point like you would on a guitar, and that point changes with the pitch. The tension was constant. However, the due date for the contest was coming up fast (To quote Douglas Adams: "I love deadlines, I love the wooshing noise they make as they go by") and so I kinda improvised by using that moving cylinder, not realizing it looked like it was stretching the string. For Bill Hancoc: It took about a month to make. For KenWittlief: It would be easy to change the camera view, the problem is the render time. I'll probably get around to it eventually. For Fimmel: I used The trial version of acid xpress 5 to make the music, And plain old 3dsmax6 for the actual animation. Everything you see was keyframed, no plug-ins or anything. P.S. Have you guys ever seen animusic? Its really awesome and it was made on 3dsmax too. (that's where I got the idea for this) Thanks for your opinions on this, it really means a lot to me. ![]() |
#12
It's pretty obvious where you got your idea, and it's pretty good - I like it. |
#13
Good job! This is some nice work.
I'd even go so far as to say its on-par with some of the Animistic videos .I can't say I like Animistic (I thought it was kinda dull) but I admire your use of 3dsmax to sync music to video. I don't know if you knew this, but the instruments in Animistic were actually programed to sync to the notes of the music. There was no human intervention in animating the clips; the instruments literaly 'played themselves'. I'm no animator, but I would be interested to know if you can do this with our version of 3dsmax, or if it takes a special program. |
#14
I like the video (and music).
It's very similiar to Animusic. And it's nice to see another animator duplicate something like it. I just noticed that two of the large string players don't play at the end. Is that part of the music or just an animation 'oops'? Was the big thing in the center supposed to be a big light? It took me a while to catch that. It does blend in with the white background a little. |
| New School Website- WANT *YOUR* FEEDBACK!!! | Joe Matt | Website Design/Showcase | 17 | 30-06-2004 16:25 |
| New Video Idea | JakeGallagher | Chit-Chat | 0 | 04-04-2004 12:20 |
| Enough pictures... I want to see some video! | f22flyboy | Robot Showcase | 7 | 02-03-2003 18:20 |
| So, you want a list of new ChiefDelphi threads IN your phpBB2 forums? | Brandon Martus | Announcements | 10 | 16-12-2002 22:12 |
| I want to welcome a new member! | Joe Matt | Chit-Chat | 12 | 20-09-2002 14:19 |
