Go to Post The closest and strongest friendships that I have formed, however, have come from the FIRST robotics program. Friends that I can call “brother,” that I can call “sister,” that I can just call “family.” - DanDon [more]
Unread 21-06-2006, 18:17
CraigHickman
Posts: n/a
pic: Coaxial Swerve drive, lightened.
Unread 21-06-2006, 18:24
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: pic: Coaxial Swerve drive, lightened.
That looks super cool. Instead of all that machining to make it lighter, you could try just using a thinner plate, such as 1/8'' or 3/16" (it looks like you have 1/4''). You can never have to many speed holes though.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 21-06-2006, 18:25
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
allot of sharp edges i see. this thing is awfully tall. you know how much side load those bushings are taking and how much shear that creates between those plates up there? i know modules that i make out of legos that are that tall don't last long. it would be nice if it were supported closer to the Axel.
Unread 21-06-2006, 18:54
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I've been curious as to why you've opted to mill pockets into the plates rather than entirely cut out large sections. Any insight?
--Madison--
...down at the Ozdust!
Unread 21-06-2006, 19:30
CraigHickman
Posts: n/a
The reasons for the lightening style is structure. As a whole, the entire module is only 8 inches tall, from the top of the power transmission shaft to the bottom of the tread.
The plates used are 1/4", and it can't be any thinner, as it's held together with bolts. As for sideload issues, Inventor 11's stress analysis tells me that it can take about 900 pounds of sideload as a whole, which just might be enough for a FIRST bot.
Unread 21-06-2006, 20:40
Joe_Widen's Avatar
You could try using Al tubing and be crafty with the cnc mill. It would have zero bolts (...gasp....). Thats how im designing mine atleast. No fancy stuff, no coaxial, just plain old spur gears and motor mounted on each module. Fancy gears are not my friend, especially after using worm gears (a thousand and one to many headaches there), although, I think helical gears are crazy cool. Good Luck to ya.
Unread 21-06-2006, 21:55
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Maintinence would be a pain though, even more so w/ the extra stuff due to the coaxial design
Unread 21-06-2006, 22:04
CraigHickman
Posts: n/a
The gear sytem for said module is a set of bevel gears (under martin sprocket as miter gears.) They give me a 1:1 ratio, which matches all of the ratios in the module. This is to make calculations for the gearboxes (maybe 2 speed?) which are elsewhere on the robot.
Unread 21-06-2006, 22:59
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
I would recommend you re-evaluate you 1/4" plate idea....1/8" bent sheet metal is more than capable.....
Unread 22-06-2006, 03:20
DB_UPS's Avatar
DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
The bent sheet metal looks easy to make and harder to screw up. Joe, you should look in to make a version this way too. So if swerve drive is a optional next year we have two ways to make it. But i do like the milling way too.
Unread 22-06-2006, 03:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Sheetmetal is only easier if you have the resources to precisely punch and bend it. Otherwise it's a disaster waiting to happen.
2001-2004: Team 100
2006-Present: Team 254
Unread 22-06-2006, 09:11
BSEE, MSEE, JD
AKA: employed
You don't have to use a punch....you could get it done by a waterjet or laser just as easy....
Unread 22-06-2006, 09:22
REVving up for a new season
FRC #2848 (All-sparks)
something tells me that teams are more likely to have a punch then a waterjet...
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 22-06-2006, 14:34
DB_UPS's Avatar
AKA: Ryan Quinlan
Good point. But 1/8 sheet metal bends really nice in a vise. You can also mill holes in it, thats if you now to do it right. So you do need a punch.
Unread 22-06-2006, 14:36
Cory's Avatar
AKA: Cory McBride
There's absolutely no way you can fabricate a swerve module out of sheetmetal by bending it in a vise--it needs to be very precise, far more than you can ever be by using such a method.
2001-2004: Team 100
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
