Yesterday, while walking through a hobby works, I bought the flexible shaft Dremel attachment. I was really surprised by how amazingly well it works. It can be bent nearly 360 degrees with very little impairment of shaft rotation. Anyways, I realized how this could be really helpful in some of the applications I had in mind. Does anyone know where I could get one that will couple with a CIM?
Re: Flexible shafts working with CIMs
Check mcmaster page 1083 and scroll down to Heavy Duty Flexible Drive Shafts
Those would probably work, but they certainly aren't cheap. And you'd have to drill/bore out the coupler to 8mm (which I presume is possible, but I'm not certain). |
So after talking with sanddrag this might not work. I need something that can handle the stress but is still cheap. Kind of a contradiction but if anyone knows of anything it would be really helpful.
I think I remember some sort of flexible shaft that came with the 2005 KOP...but I dont know any more information regarding it.
you could try to work with one out of a junk weed eater just look at the junkyard for like 50 cents they can't be the type with a strait shaft =it must be one with a curved have fun!!! i love the junk yard
| Working with Gyros | DavidSJohnson | Programming | 1 | 10-02-2006 00:16 |
| Working with Lexan | Phil Paspalas | Technical Discussion | 41 | 09-02-2006 16:14 |
| Building fully flexible tail (several joints) with minimal actuation required | sanddrag | Technical Discussion | 51 | 27-11-2005 18:05 |
| Shorten The Flexible Drive Shafts? | milesdf | Motors | 2 | 08-02-2004 12:27 |
| Working with Potentiometers | GrahamS314 | Programming | 11 | 02-02-2003 14:34 |
