Go to Post In this case, "non-thermal protected" would mean "future paper weights." - Rick TYler [more]
Unread 08-07-2006, 03:26
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Exclamation Help with VPN router
I have recently purchased 2 used Radguard vpn routers. Both display invalid data key on the LCD screen.
I so far can;t find any information about this error, and any info at all on these devices.
If anyone could help I would greatly appreciate it.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 08-07-2006, 10:59
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: Help with VPN router
I am unfamiliar with this particular router. However on almost all routers have a reset button on the back of them, which restarts the router to factory conditions. If that doesn't work, it maybe corrupted firmware, and you must replace the firmware.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 08-07-2006, 12:35
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Well, I have some bad news for you and some very helpful news.
According to this article, Radguard is history. They will not be providing you any support any time soon. Here is a quote from the article. "In the parlance of The Princess Bride's Miracle Max, VPN vendor Radguard is not just "mostly dead"; it's "all dead.""
Here is a link to what appears to be an Operators Manual for a Mobile, ie. PDA, Client for use with this VPN Router. Better yet, it includes a section on configuring the router for use with this client.
This document, though it is written on how to get the Radguard to work with Snapgears' VPN router, has a section on configuring the Radguard as well. It may give you some insight to what's happening.
Here is a quote from this article. "Radguard and ADI were fairly weak in reporting; their messages were rather sparse and cryptic, and not very informative at first glance." That doesn't sound too good.
Lastly, these guys sound like they may be able to help. Good luck, I found not a single hit while searching their site about your error massage. Although, I didn't try contacting them. That might yield better results.
Unread 10-07-2006, 08:32
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Most VPNs use a public key / private key security and PPTP transfer protocol. As such they need to be hooked up to the network (local area or internet) to receive the public key. This means that BOTH devices need to be turned on, connected to each other, and each have the others public key.
If all you are doing is turning them on, without hooking them to a network, they will not receive the public key. And will display invalid data key.
If they are setup on a network then you may need to go into the router [telnet in or us IE (usually IP addy 192.0.0.1), there most likely will be a username/password pair required] and reconfigure them so that they both will use the same protocol and public / private key (you may be able to do this by setting them back to factory defaults and having them hooked together and 'find' each other). Also make sure they are both using the same encryption security protocol (Kerberos or DCE).
Good luck getting them to work.
Unread 10-07-2006, 13:33
Scott L.'s Avatar
Lightbulb Re: Help with VPN router
Thanks for the help. I will try these suggestions.
Help with Programming double_check Programming 11 19-08-2005 00:15
Linksys Router Help mtaman02 Chit-Chat 10 18-03-2004 01:04
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Help with Pnuematics inwoodraider Pneumatics 3 30-01-2003 17:27
Help with Gearboxes D. Gregory Technical Discussion 27 03-01-2003 14:31
