Go to Post Ahhh... the beauty of an exponential series... - dtengineering [more]
Unread 10-07-2006, 16:37
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Insufficient wheel-axel friction
With increasing time and wear, we are finding that wheels, formerly held on by friction, routinely fall off. While it would be far more robust to secure the wheels by affixing a collar at the end of the axel, 3-inch axels aren't long enough to do the job. We are thinking of cutting our long axels into 3.5 or 4-inch lengths, but were wondering if anyone has a cheaper solution.
Unread 10-07-2006, 17:06
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
Re: Insufficient wheel-axel friction
How about attaching your sprocket to your wheels instead of to the shaft. This way your wheel and sprocket would be a free spinning entity on the shaft. This is how 229 has done it for at least the past 3 years. Example
Hope this helped,
JT
229
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 10-07-2006, 17:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Hope this helped,
JT
229
I think ManicMechanic was looking for a solution to this problem on the Vex robots.
Since you cannot really have dead axles in Vex, I would suggust trying to "shift" the axle outward if you need an extra quarter inch or so to get the shaft collar on. If there is any "extra" shaft on the inside of the robot frame, try to get this extra onto the outside.
Also, by rearranging the location of the shaft collars on the inside of the Squarebot you can minimalize the amount of axle needed there, so that you should be able to have enough axle on the outside of the robot next to the wheel in order to get a shaft collar there.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-07-2006, 17:38
Wow, I guess I really spaced out on that one. Sorry about that.
Mounting encoder/cutting 12 in axel intellec7 FIRST Tech Challenge 8 12-04-2006 12:55
Live axel on kit skyways? Bill_Hancoc Technical Discussion 10 16-03-2006 17:38
Attatching an axel to a wheel Zoheb N Technical Discussion 36 12-12-2005 13:43
Crazy Frog - Axel F Elgin Clock Chit-Chat 23 24-09-2005 22:04
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
