Go to Post Big scoop for everyone here: All divisions are stacked with talented teams. It's like this is a really big event or something. - PayneTrain [more]
Unread 17-07-2006, 18:40
Eric W. Jones's Avatar
Eric W. Jones Eric W. Jones is offline
Rack & Roll, baby!
FRC #1646 (Precision Guessworks)
Eric W. Jones will become famous soon enoughEric W. Jones will become famous soon enough
Globe Motor Programming Questions
I am the (extremely) green head student programmer for 1646. I have very little practical experience programming in C, and I would appreciate any help anyone can provide.
::Long Intake of Breath::
Now for the question. We have recently installed a globe motor onto our robot and I need to know how to program it. I would greatly appreciate any advice or links provided by more experienced programmers.
Unread 17-07-2006, 18:52
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Globe Motor Programming Questions
First you need to wire the globe motor to a speed controller, then connect a PWM wire from the speed controller to one of the PWM output on the robot controller... to controller the motor from your program you set the PWM output to a certain value..
Assuming you connected the speed controller to PWM output 1
pwm01 = 0; // Full backward
pwm01 = 127; // Neutral (motor doesnt move)
pwm01 = 255; // Full foward
If you connect it to another output just change the pwm number (pwm01, pwm02, pwm03, etc...)
You can choose any value between 0 and 255 to move the motor at different speeds and directions...
You can also map it to a joystick..
pwm01 = p1_y;
This is set the motor speed to the value of the y axis on port 1
Hope that enough to get you started...
Unread 17-07-2006, 23:37
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
A word of correction - the full forward value should be 254, not 255. This is because the control system uses two values of 255 to mark the beginning of a radio packet, so if you assign 255 to a PWM output variable it will wreak havoc with the radio communications.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 18-07-2006, 01:10
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
On my team we have set PWM outputs to 255 and there were no known problems that occured because of it. It may be because PWM 1 to PWM 10 all have some other byte that is sent before it and none of them were ever valued at 0xFF, or maybe it is automatically adjusted in the Putdata function.
I am relatively new at this, so I'm not really sure what if what I am talking about here is entirely correct.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 18-07-2006, 09:36
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
All the responses here so far have been generally applicable to any of the motors in the FRC kit of parts. Do you still have a question that relates specifically to the Globe motor?
Richard Wallace
since 2003
Unread 18-07-2006, 14:29
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
I set motors to 255 all the time and have had no problem with it...
Unread 19-07-2006, 08:57
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
We do not use 255 for a pwm output since it may cause an issue.
Also be aware that there is a dead band of ~ 4 pwm counts around the neutral (pwmXX=127) position. Thus 123-131 tend not to move the motor.
Also, The speed of the motor going full forward may (probably will) differ from full speed reverse.
Unread 19-07-2006, 20:34
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I just do this:
if ((pwm01 > 127) && (pwm01 < 251)) pwm01+=4;
else if ((pwm01 < 127) && (pwm01 > 3)) pwm01-=4;
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 19-07-2006, 20:37
Circuit Breaker
Originally Posted by Qbranch
I just do this:
if (pwm01 > 127) pwm01+=4;
else if (pwm01 < 127) pwm01-=4;
Um... wouldn't that cause pwm01 to overflow at values near 254? (and underflow at values near 0?)
Patrick Fairbank
patfairbank.com
Unread 19-07-2006, 21:00
AKA: Alex
Yeah it does, i was originally only referring to taking out the deadband. I just edited my post and added the limit code in.
-Q
Unread 20-07-2006, 04:00
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
To respond to the original question; the type of motor is not incredibly important as long as it runs on a PWM signal. What you need to do is set your PWMs as shown in the first response and assuming you are using the FRC robot controller and default MP labs code it will convert that data into a usable signal for any standard PWM motor.
Unread 02-08-2006, 19:04
Rack & Roll, baby!
We've generally avoided getting the pwms too close to 255. We just put in some code that says something like:
if(p1_y >= 250)
pwm01 = 250
this has worked well for us in the past, as if the pwm output exeeds 255, then it will loop back onto itself and tear up your motors. A pwm output of 256 is essentially 0.
If I'm wrong, please correct me.
Unread 03-08-2006, 08:37
You're correct that if pwm01 gets set to a number greater than 255 it will wrap around to zero and you'll suddenly go from full forward to full reverse.
A note on using a pwm value of 255.
The reason to avoid using the value 255 is that sequential 255's in a transmission packet is the standard indication of the beginning of a packet, so if pwm03 and pwm04 (which are side-by-side in the transmission packet) were both transmitted as 255 the packet handler would think pwm05 was really the start of a transmission packet and the OI would be handed really bogus data.
Those of you allowing 255 are protected from the adverse effects, because the Master code takes all your carefully set values of 255 and changes them to 254 anyway. You can test this by setting the pwm values to 255 in your code, then using the Dashboard to see what values actually arrives at the OI.
Unread 04-08-2006, 20:40
DonRotolo's Avatar
Back to humble
FRC #0832
Please note that the motors here run on Direct Current. They are NOT "PWM" Motors. We use a PWM signal to control a Motor Speed Controller (such as a Victor) which varies the DC current* to the motor, making it move at different speeds and such.
However, the point that the motor type is not particularly important is absolutely correct.
*Technically speaking, it is a pulsating signal at a relatively high frequency, so high that the motor reacts to the current as it would react to a variable DC signal.
Unread 08-08-2006, 15:03
AKA: Alex
Matt something you may want to try sometime to understand better the premise on which PWM motor control works is examining the output of a Victor or other H-Bridge Drive's output.
If you have access to an oscilloscope, hook the probe end to M+ and the alligator clip to M-, and set your oscilloscope to trigger on a rising edge. Then use a joystick to vary the 'power level' (duty cycle percentage) to the motor. As the speed of the motor changes, watch what the ratio of up and down time on the pulse train does.
If you have any questions i'll be happy to answer them.
-Q
globe motors arabsponsor Motors 16 29-01-2005 00:12
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Globe Motors? Brett W General Forum 3 10-01-2003 21:13
Globe Motors archiver 2000 1 24-06-2002 00:15
Spare Globe Motors archiver 2000 9 23-06-2002 22:48
