Robots tilt
just curious for the teams that have i tilt on their robots with the wheels how big of a tilt is it
Re: Robots tilt
I'm immensely confused with what you are asking. Could you clarify your question?
Re: Robots tilt
sorry i did word that oddly.
The robot we are building right now has a slight tilt so it can turn easier. does anyone else have this and if so how much of a tilt |
Re: Robots tilt
Re: Robots tilt
so you mean
regular wheels being like this (vertical) | | and your tilted wheels being like this / / or this / or this / hope that helps edit: i am saying / /, / \,\ / because certain machines tilt their wheels like that. Last edited by lrdblaster03 : 18-07-2006 at 15:31. |
Re: Robots tilt
I think what lrdblaster03 is talking is something on ATV's. If you notice in this pic, the front wheels are mounted on an angle. So the real question I think is do you mean lowered wheels as in a 6wd configuration, or do want angled wheels for easier turning?
#7
Re: Robots tilt
I'm not really sure how angled wheels would provide easier turning (I have seen teams do this for some odd reason I've yet to understand), but in a 6wd setup, many teams choose to lower the center wheel so that there can be at most 4 wheels on the ground at any given time. I've found 3/16" offset to be sufficient. Personally, the rocking (tilting) with 3/16" offset was a bit of an annoyance for me. But this was for the Triple Play game where we were trying to place a tetra with a long arm. I'd split the difference between 3/16" and 1/8" and set it at 5/32" (if you keep tolerance on these sort of things to that small). Of course it somewhat depends on what tires/tread you are running. Anything over 3/16" I think would be excessive and anything below 1/8" would be too small.
#8
Re: Robots tilt
no no no...Arefin Bari had it right. Im not tilting the wheels im lowering the middle wheel so the robot can tilt
#9
Re: Robots tilt
2004 robot had a four wheel design with 4WD, and we had many problems with turning. Our 2005 and 2006 robots had 6WD with the center wheel slightly lower than our two outer wheels. If you use a pneumatic wheel for the center, you can adjust how offset the center wheel is. |
#10
Re: Robots tilt
Re: Robots tilt
I know the middle wheel drop has been established as the thread's intent. I just thought I would throw this out there. |
#12
Re: Robots tilt
Didn't 229 have something similar to this with 8WD? The two inner-most sets of wheels were lower than the front and back set.
#13
Re: Robots tilt
25 Doesnt lower their middle wheels at all....
#14
Re: Robots tilt
This year we lower the center wheels about a quarter inch, but also ran a lower pressure in the outer wheels.
#15
Re: Robots tilt
60 and 254 both did this for their 2004 machines. Not sure if they still use it but their current drive systems are similar.
| pan & tilt errors | itzrobz | Programming | 2 | 19-02-2006 19:12 |
| Grabbing Tilt Angle? | crossedheart | Programming | 7 | 09-02-2006 03:08 |
| CMUCam2 GUI Tilt Question | Idaman323 | Programming | 3 | 27-01-2006 02:01 |
| Tilt Troubles | Mumford 406 | Programming | 4 | 29-03-2005 22:19 |
| Weight needed to tilt bridge... | archiver | 2001 | 4 | 23-06-2002 23:43 |
