Go to Post You are not limited by your resources, but by your imagination. - John Gutmann [more]
Unread 15-08-2006, 16:03
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Wiring battery pack to motor via switch...
OKay... so I've never wired anything before and I want to make a mini poof ball launcher...
How do I wire the battery pack (2 AAA Batter Pack) to a toggle switch and then to a small 1.5-3V DC hobby motor? Again, I don't know jack squat about wiring and don't know where to look to find an answer to this question.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 15-08-2006, 16:31
Re: Wiring battery pack to motor via switch...
picture the electricity flowing like water
it flows out one side of the battery, into one side of the switch, out the other side
into one side of the motor, out the other side
the back into the other side of the battery
when you turn the switch on the power flows round and round
when you open the switch the connection is broken, and it stops
Unread 15-08-2006, 16:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Well, you can get a two AAA battery holder and a toggle switch (or other kind of switch) from Radio Shack. For simplicity, get a toggle switch with only two terminals, kind of like this. This is called an SPST switch, Single Pole, Single Throw.
Then, take one wire from the battery holder, and connect it to one terminal of the switch. Take the other wire from the battery holder and connect it to one wire of the motor. Then take the other wire from the motor, and connect it to the other terminal on the switch. That's all there is to it. You are basically hooking the two motor wires to the two battery pack wires with a switch to "break" the connection along one of them. In this application, it doesn't matter what color goes where. If the motor is running "backwards" swap the wires.
Unread 15-08-2006, 18:06
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Thanks a bunch. I would have never figured that out.
Do The Tyler!
Unread 15-08-2006, 18:42
FIRST JerseyKid's Avatar
FIRST JerseyKid FIRST JerseyKid is offline
Alumni
AKA: Erik Cokeley
FRC #0025 (Team Mercury)
FIRST JerseyKid is on a distinguished road
Send a message via AIM to FIRST JerseyKid Send a message via Yahoo to FIRST JerseyKid
I would also suggest getting some capacitor and resistor and putting it in parallel with the switch, as a snubber.
|-----cap---resistor-----|
----- switch -----------------
This helps protect voltage spikes through your motor, because your motor acts as an inductor. It'll help with your motors lifetime.
Team 1089 alumni coach.
Unread 15-08-2006, 18:50
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Make sure the switch is rated for at least as much power as you plan to put through it, nothing like melting a toggle switch!
Matt Krass
IR Switch Wiring sgsdragons Electrical 2 14-02-2006 03:26
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
VEX Battery Pack Runtime? TennBikeBerk FIRST Tech Challenge 4 04-08-2005 18:12
Wiring a switch stevex Electrical 3 16-02-2005 08:31
Wiring Pneumatics Switch Simpson Pneumatics 3 11-02-2004 12:32
