A new drivetrain Idea?
![]() OK here it is: it is a regular four or six wheel drive, except that each side of the drive train (the blue parts) would splay out to allow driving in arcs. Depending on what angle you expanded them to, you would drive in a larger or smaller arc; If you expanded them to 45*angle, you would travel in a mid-sized arc, and if you expanded them to an 87* angle, you would travel in a very large arc. There would be a platform suspended on casters between the sets of wheels (the red part) for mounting any mechanisms that you needed to. The top "diagram" would be fully closed, which would allow you to drive normally; and the bottom one would be fully open, which would allow you to drive sideways. Am I missing anything that would make this not work? P.S. I apologize for using paint, It's all I have at the moment. ![]() |
Re: A new drivetrain Idea?
Oh yea and how are you going to program that thing to go sideways? when hinges are closed it can go forward and backward but when you open the hinges and wheels are 180 degrees, wouldn't each side try to fight against each other? Last edited by Arefin Bari : 18-08-2006 at 00:00. |
Now, for programming it to go sideways, you could just program it with tank drive and make the x-axis on the joysticks move the robot side to side when it is open. |
It would be interesting to see a robot with two sets of these, effectiving spreading your drive wheels to a wider and longer wheel base when open
and changing the 'front' of the robot by 90º |
#7
In 2005, 648's robot could extend to give it more stability. I don't remember the exact stats but it almost doubled it's short side. How we got it to do this was just lock the back wheel and power the front two wheels and then it would lock into place with servo actuated hooks. When we when back to get into the box all we would have to do was lift the hooks with the servos and squish back together.
This concept made me immediately think of that robot. |
#8
I personally think that it is a very innovative idea which can amaze some people if properly designed and built. This design doesn't have to be used particularly for a FIRST robot, but can be used for demos and offseason projects.
As far as the rule <R08> goes (after the start of the match the robot may expand up to a maximum volume of 60 inches by 60 inches by 60 inches)... there have been teams who have made their base shorter than 38x28 (bot had riggers and so forth but after full extension they were in the size limit). The problem Ben pointed out earlier is one of the very important component of this design (if you are building this chassis for a FIRST robot according to last year's rule) but there are ways to avoid the chassis extending more than 60". I do agree with you Ben where you said it's a very complex design, but how cool would it be to see something like this on a FIRST field. ... keep going Cody, show us your next step to this design. p.s. - I am still waiting to hear from Baker, Neun, and Copioli about what they think about this design. |
#9
I'm not trying to crash your idea but I think that it would have to be thought out just a little bit better. I am a fan of creating new drive systems. It would be hard to convince me that this would work, and what are the advamtages to having this over a typical swerve drive?
#10
Well that's interesting!
If you had a particular design problem you were trying to solve, I'd say you might want to open it up to other possible solutions. But it SEEMS like you are floating an idea to see what other people thing - which is great! Being creative for creative's sake is great - you don't always need to be engineering a solution to a problem. Let's say this never becomes a FIRST robot drivetrain - I bet it still gives you ideas on some other FIRST mechanism. Or - it made me think of this... an unpowered cart to carry stuff (maybe a FIRST robot) that folds up for easy shipment and storage in the pit. BAMN - already a use for FIRST. Thanks for sharing! |
#11
hey, fin What about a ball caster? They reduce the movement that a normal caster has. Page 1224 of Mcmaster Carr is a threaded stem ball caster. ![]() |
#12
If it cant go sideways, its called a wheel! [ºiº] Last edited by KenWittlief : 18-08-2006 at 14:08. |
#14
Hmm very interesting. very cool idea. i am inspired yet faced with a complex and perhaps frivolous challenge without much rewards as far as a competitive drive train None the less. as such i post the question in what situation fanciful, practical or otherwise do you see this machine being an advantage? once you have come up with an answer that satisfies your curiosity and overcomes any laziness you may or may not have incurred through your youth to design such things. bring your design to life through a drawing, a model, an animation , a cad drawing, whatever and then use that to assess and further your creativity. I relay like this idea and i think its relay cool. i have some ideas of variations that could be made to make it simpler and more controllable but and I'm shure you will come up with some too. Please let me see this as a beginning of a new robot designer. they're aren't many people that can come up with and fabricate unique ideas and innovations like that.
| new award idea | ewankoff | General Forum | 16 | 05-04-2006 14:08 |
| Questions about an Idea for a drivetrain. | Radiator251 | Technical Discussion | 21 | 29-01-2006 13:11 |
| Crazy drivetrain idea | lukevanoort | Technical Discussion | 7 | 26-10-2005 21:19 |
| Crazy NEW Idea! | Kyle Love | Championship Event | 14 | 07-11-2004 16:50 |
| New Format - Good Idea/Bad Idea? | Harrison | Chairman's Award | 4 | 07-11-2002 16:28 |
