pic: Team 177 2005 Transmission
Re: pic: Team 177 2005 Transmission
Sorry to be slightly off topic, but my question does relate to something in the picture. Were those welds done with a MIG or a TIG? If they were done with a MIG, what are the specs on the machine and how does it work out for you?
And yes, nice transmission. ![]() Last edited by sanddrag : 20-08-2006 at 21:07. |
Nice transmission. How did it work out for you guys?
It looks like it's an attachment onto the kit transmission.
Did you do this to get a two-speed transmission with half of it already designed for you? |
#7
I'll try and answer as much as possible.
We TIG EVERYTHING in the 177 shop. We have Miller Electric machines that UTC Power, sponser I for, donated when we down sized our factory space a few years back. The person who does most of our welding is one of the our recieving inspectors who used to weld pipe and tube in the shop. If you saw our robot this year that was all 1/16th wall box welded. We didn't pop a weld. We used the output of the kitbot tranny as our low gear. After the UTC scrimmage we discovered that we needed a high speed. We utilized parts designs from our 2004 transmissions so we could save time and make the these in 2 days. Do to this I only had 2mm key to use to lock the drive shaft to the output gears. We knew this was the weak point but didn't want to weld everything in place in case we needed to service something. The failure Kim and Greg mentioned is the key shearing. This wouldn't have been an issue if we had had the correct key to begin with.Pete |
#10
Can we see a simple diagram of the gearing itself? If the transmission is still around, perhaps you can take sideview picture to better see what you have here.
#11
Matt B. |
#13
What size wheels were on this particular 177 2005 robot?
| pic: Team 177 Mosaic | Greg Marra | Extra Discussion | 4 | 09-03-2006 00:57 |
| pic: 222 2005 ball bearing style shifting transmission | team222badbrad | Robot Showcase | 2 | 11-03-2005 14:17 |
| pic: 177 2005 Transmission | Peter Matteson | Robot Showcase | 1 | 24-02-2005 07:55 |
| pic: Team 326's new Transmission | Mr.G | Robot Showcase | 12 | 16-02-2005 13:12 |
| pic: Team 30 Dual-Motor Transmission | CD47-Bot | Robot Showcase | 27 | 10-02-2004 18:35 |
