Go to Post The few people who don't ever make mistakes are the same people who simply don't do anything. What people do after they make a mistake tells others what they are made of. - Andy Baker [more]
Unread 24-08-2006, 20:36
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Kevin Watson and programming VEX in MPLAB
Who has programmed a VEX in MPLAB using Kevin's code? I am currently looking at the gyro code and wondering how Kevin's code works on a VEX.
Doug Leppard
Unread 24-08-2006, 20:43
Re: Kevin Watson and programming VEX in MPLAB
Open up the vex source code, and import kevinsfile.c and kevinsfile.h. Follow the setup procedure in the documentation. It should "just work."
Make sure you include the old pic headers (pic8250.h) if you are using 2006 code.
Unread 24-08-2006, 20:50
Thanks. Have you done it?
I don't see kevinsfile.c or h on his page. http://kevin.org/frc/
Where do I find that?
Doug Leppard
Unread 24-08-2006, 21:01
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Heh, he means the project code that you want to use. Eg: gyro.c/h, encoder.c/h, etc.
http://www.mikesorrenti.com/
Unread 24-08-2006, 21:05
OK that is what i am doing. putting in the gyro code was OK, but it had ADC.C dependencies and that was more complicated, so I wanted to make sure that it was OK before i did it.
Doug Leppard
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Trouble using Kevin Watson's Serial Code with Vex user API StargateFan Programming 3 13-01-2007 15:42
Vex Programming with MPLAB and IF loader Joohoo Programming 3 27-07-2006 18:18
MPLAB Help, programming and compiling RedOctober Programming 2 23-12-2005 17:46
