Go to Post Once you go hex you'll never go back. - sdcantrell56 [more]
Unread 28-08-2006, 17:11
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
main.c
in the main.c
while (1) /* This loop will repeat indefinitely. */
#ifdef _SIMULATOR
statusflag.NEW_SPI_DATA = 1;
#endif
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
{ /* I'm slow! I only execute every 26.2ms because */
/* that's how fast the Master uP gives me data. */
Process_Data_From_Master_uP(); /* You edit this in user_routines.c */
if (autonomous_mode) /* DO NOT CHANGE! */
User_Autonomous_Code(); /* You edit this in user_routines_fast.c */
Process_Data_From_Local_IO(); /* You edit this in user_routines_fast.c */
/* I'm fast! I execute during every loop.*/
} /* while (1) */
shouldn't it be
if(autonomous_mode)
else
otherwise it will be executing Process_Data_From_Master_uP() and then User_Autonomous_Code() in auton, every loop, thus eating up a lot of processor time.
Unread 28-08-2006, 17:24
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: main.c
If you take a look at User_Autonomous_Code() in user_routines_fast.c, you'll notice that there is a loop inside the funciton that the controller will not leave until autonomous is over. So no, it shouldn't be since the program can't return to execute Process_Data_From_Master_uP() until autonomous has ended.
Unread 28-08-2006, 21:29
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: main.c
It's also worth mentioning that getdata() isn't called (and the autonomous flag set) until Process_Data_From_Master_uP() is called. Personally, this is a bug to me. Of course, I've also changed that layout anyway, so it doesn't bug me.
Unread 29-08-2006, 02:19
6600gt's Avatar
AKA: Lohit
Re: main.c
whoops...I missed the while loop in user_routines_fast.c...
Anyway, thanks for letting me know
Rewriting main loop Max Lobovsky Programming 4 04-01-2005 18:35
Editing Main.c Astronouth7303 Programming 22 20-02-2004 16:45
Main Circuit Breaker Yan Wang Electrical 6 20-02-2003 10:23
Main Stage archiver 2001 3 24-06-2002 03:06
main driver Kaitlin Palmer Off-Season Events 0 09-04-2002 21:26
