Go to Post Anything is capable of happening in FIRST. - Dorienne [more]
Unread 30-08-2006, 13:51
thegathering's Avatar
thegathering thegathering is offline
Angry Troll Lurking in the MUD
AKA: Ben
FRC #1885 (Robocats)
thegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to behold
Send a message via AIM to thegathering
Inverted color mind tricks!
Here's what you do. Take a picture, any picture with vibrant colors and make a gif that will play tricks on your eyes to make a colored image where there is none.
Step 1: Open up photoshop or Gimp (which is what this tutorial was written for), open your image, and draw a dot in the center.
Step 2: Make a duplicate of your image and convert it to Greyscale. Follow that by converting it to RGB again. It should now be a black/grey/white image.
Step 3: take the original image and invert the colors.
Step 4: go to the grey image and create a new layer.
Step 5: copy all of the inverted colored image and paste it on top of the layer you created on the grey image.
Step 6: You should now have 2 layers, the bottom a greyscaled image of the original and the top an inverted version of teh original.
Step 7: Now index your image as you always would with a .gif
Step 8: Save your image as <yourname>.gif and save the layers as an animation. Select one frame per layer and set the frame time to 10000 milliseconds or 10 seconds.
Step 9: Make sure it works and post it up here!
Here's one that I made:
Stare at the dot as it goes through it's frames. Surprise!
*2006 Champion Rookie All Star Award.
*2 x 2006 Regional Rookie All Star Awards.
Unread 30-08-2006, 13:58
Re: Inverted color mind tricks!
AhhhhGGGGG!! my rods and cones are burned in! u°}
Unread 30-08-2006, 14:01
AKA: Ben
Originally Posted by Michelle Celio
I don't get it..
Keep staring at the dot. You also really can't move your eyes. You HAVE to keep your eyes on the dot to see it.
Unread 30-08-2006, 14:38
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Sweet...
Must have color blind friend try to make sure it is color blind compliant.
Unread 30-08-2006, 22:32
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
I take it that it is supposed to make the black and white image seem like it has color? All I get is a hint of green in the background. Is there some way to slow it down to give a longer stare time at the funky colored version? My eyes must be slow to train...
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 30-08-2006, 23:17
try turning up the brightness on your monitor maybe
and hold your eyes perfectly still while the weird color is displayed, and when the B&W image comes back
its weird, cause you see a colored photo, and you wonder if its a trick, so you move your eyes, and the color is gone.
BTW, the puffins head is mostly B&W no matter what, but the beak looks reddish/brownish
Unread 30-08-2006, 23:19
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Now that is just awesome...
Unread 30-08-2006, 23:25
Onward through the fog.
The beak turns a bright aqua turquoise as well as an inner line following the eye.
The background turns a marbled, mottled purple with dark green added into the mix at the bottom -
I don't see reddish/brownish -
~ Helen Keller
(1880-1968)
Unread 31-08-2006, 12:05
Originally Posted by Jane
To me it turns into an x-ray sort of look. The puffin looks like the x-ray against a film of color. It's not like a painting or a coloring book, it looks like gels for lighting sort of. And it *pops* b-i-n-g from one to the other.
The idea is to stare at the funky colored one and then when the grayscale one pops in, your brain colors it with the opposite colors and you see a "normal" colored image of the puffin. This one just isn't really working for me..
... BTW, the puffins head is mostly B&W no matter what, but the beak looks reddish/brownish
I think this is what I get, some green in the background and some hint of red on the beak. I still think if I could stare at the funky colored image longer, I'd see more color on the grayscale image.
Cynette
Unread 31-08-2006, 12:40
AKA: Ben
Gosh, you guys sure do have weird eyes...
Here's a new one that should be MUCH easier for even the most colorblind of you to see
But keep in mind, the purpose of this thread is to make your own!
Unread 31-08-2006, 13:44
is that like speaking loudly and slowly, with a chinese accent
to a chinese person
as if that will allow them to suddenly comprehend english ?!
Unread 31-08-2006, 13:52
AKA: Ben
to a chinese person
are you colorblind?
Unread 31-08-2006, 16:02
...But keep in mind, the purpose of this thread is to make your own!
Yeah, but I don't "Photoshop" or "Gimp" so I can only rely on the efforts of others to experience this wonderful phenomenon of the human brain.
Cynette
Unread 31-08-2006, 17:31
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
The flower works much better. It surprised me when it changed. I was like "Wait a minute... it's in color!"
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 30-08-2006, 23:33
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Originally Posted by Elgin Clock
Sweet...
Yeah, I saw that post coming ...
So yeah, I am not feeling the whole color vibe in this picture. I am supposed to stare at the dot, not move my eyes, and then when it changes see normal color? I notice some weirdness, but I don't think the colors are even right when that happens (nothing is ever the right color, so thats my normal at least). When I go to look at colors, I have to stare at them to identify them. Since that throws the whole thing off, I can't get it.
Fun fact: Want to know another thing that is not colorblind compliant? The chargers that FIRST provides in the KOP every year. ohh fun times in the pit
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
Camera Picture is Inverted winners Programming 2 27-01-2006 20:09
IR signals inverted Atheist Electrical 10 08-02-2004 16:27
K3 ... teaching an old K-9 new tricks... Joe Johnson Robot Showcase 5 26-01-2003 21:50
Stupid Team Member Tricks George A. Chit-Chat 18 03-12-2002 16:25
scouting tips and tricks Rick Scouting 1 08-01-2002 00:52
