Go to Post So I guess this is just another case of someone reinventing the leg? - petek [more]
Unread 31-08-2006, 14:01
Dick Linn's Avatar
no team (Synergy)
Possibly useful - 33:1 gearbox
Harbor Freight has a hand-cranked lugnut remover with a 33:1 ratio on sale for $16.99. It's a little heavy, but it has an aluminum case and you could throw away the steel handle and pivot and cut off part of the mounting arm. It's sloppy, but might be very useful for a high torque, low-speed application like raising an arm, aiming a device or raising and lowering a retractable caster wheel. Item # 93645. Just a thought.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-09-2006, 00:12
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: Possibly useful - 33:1 gearbox
Wow... although I've never thought of Harbor Freight to sell durable products. My hammer from the dollar store lasted longer than the one that I got from Harbor Freight.
Although a 33:1 ratio is kinda out there, it would work very nice to raise an arm.
Edit: The ratio to raise and lower my Vex robot arm is 7:1 and it moves extremely slow. So I wonder how slow that ratio would be, but then again it depends on the motor you attach it to. And then you could put it to be 1:33. Super fast. Not extremely useful in FIRST but maybe in a combat robot. LOL.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 01-09-2006, 11:44
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
yes but the vex motors are gear motors and have a very big reduction in the case of the motors, yes hf is bad unsealed bearings in a water pump
Unread 03-09-2006, 17:32
Andrew Blair's Avatar
FRC #0306 (CRT)
33:1 on a CIM is about 2.5 rev/sec. Perfect for an arm if you add in a small reduction before hand. But it would seem like a big modification perhaps.
-Sir Francis Bacon
-Albert Einstein
Unread 04-09-2006, 23:28
Dick Linn's Avatar
no team (Synergy)
You might be able to use it without reduction by using some sort of cam arrangement - depends on how much you want to raise it.
I did see the exploded parts diagram of this. There's an internally toothed annular gear around the outside, and what appears to be two inner gears with some eccentric shaft. It's hard to see from the drawing just what is going on.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 07-09-2006, 00:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Even better. $14.99 http://www.harborfreight.com/cpi/ema.../images/17.jpg
Supposedly the coupon is good Sept 15-21
Unread 07-09-2006, 21:42
FRC #0306 (CRT)
Is that only good in Pittsburgh? I just noticed the label in the top corner.
<EDIT> Wow, I feel dumb.</EDIT>
-Sir Francis Bacon
-Albert Einstein
Unread 20-09-2006, 15:57
Dick Linn's Avatar
no team (Synergy)
There's a picture and more discussion here: http://www.chiefdelphi.com/forums/sh...ad.php?t=49073
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 20-09-2006, 16:01
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Also here: http://www.chiefdelphi.com/forums/sh...ad.php?t=49064
One thread is about the innards of the torque multiplier, another is about a possible application.
Richard Wallace
since 2003
Unread 01-09-2006, 23:10
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Do you have the complete item number for the $16.99 sale price? It comes up at $29.99 on the HF website and the sale price in the latest catalog I have it $19.99. I am heading to HF sometime this weekend and if they have them I might pick one up for the $16.99 sale price and open it up to see how it looks inside. The local store will match the $16.99 sale price if I can print it out from the website.
Unread 02-09-2006, 11:18
Dick Linn's Avatar
no team (Synergy)
The item is in a printed flyer I just received in the mail. Item 933645 is all it says. The local store should have a bunch of the same sale flyers. Sale ends 9/25. You could call a store and check price/availability. As I say, these are sloppy and definitely something for a slow speed actuator or similar task. If someone needs a 15:1 gearbox for a reasonable price, check this: http://www.surpluscenter.com/item.as...ame=powerTrans
it's for a lawnmower, so it should handle some power. A bit heavy unless you cut off a lot of the shaft.
Harbor Freight also has digital voltmeters on sale for $3.00 Great for loaning out to people who check voltage using the resistance range
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 02-09-2006, 13:01
I got one at my local HF store for $16.99. It didn't appear on the sale flyer (or at least neither the store clerk nor I could find it there) but the sale price did come up when they scanned it at the register.
Does anyone have photos of the gearing inside?
Richard Wallace
since 2003
Unread 03-09-2006, 12:12
Dick Linn's Avatar
no team (Synergy)
It's $19.99 in the Aug sale flyer, $16.99 in the Sept sale flyer. There might be a picture or gear description in the manual (on line).
Check the on-line manual at Harbor Freight. Perhaps it has an exploded parts diagram. My Acrobat reader decided not to work at the moment...
Others are selling this as the "EZ-Lug" for $50-$60. I wonder if there's any difference in quality?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Championship Event in Atlanta for 2007 = Confirmed (possibly 2008 & 2009 too) Elgin Clock Championship Event 18 24-08-2005 00:37
New Team to be (Possibly) Started at Cal Poly Pomona A. Leese Starting New Teams 13 10-03-2005 01:51
BrowserCam - Useful Tool Yan Wang Website Design/Showcase 6 04-08-2004 22:25
