Go to Post We're not here to build robots. We're here to build students. - GreyingJay [more]
Unread 16-09-2006, 18:37
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
2006 FVC Game field photos?
I know it may be early to ask this but does anyone have any photos of the hangin-a-round game field im currently out of ideas and mabey seeing a real field will help
-Dustin Benedict
Unread 16-09-2006, 19:26
Billfred's Avatar
Billfred Billfred is offline
Re: 2006 FVC Game field photos?
I haven't seen any photos of the Hangin'-A-Round field in the metal, but you might profit from a nice wide shot (try http://www2.usfirst.org/vex/2006/200...escription.pdf ) or the game animation.
Or, alternatively, build some mock-ups of the parts. You can build the goals, both low and high, for about the price of a couple of twelve-packs of Mountain Dew (hint: when it says Lexan, think hardboard or luan), and the center structure can be made for cheap as well. Look here for the field Bill of Materials and some options for low-cost fields.
Unread 16-09-2006, 20:06
thefro526's Avatar
Mentor for Hire.
thank you i might have to make a run to home depot tommarow...
and a twelve pack of mountain dew doesn't to bad either
What is Laun
-Dustin Benedict
Unread 17-09-2006, 08:17
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Originally Posted by thefro526
thank you i might have to make a run to home depot tommarow... What is Laun
You mean luan... Luan is a lighter, and cheaper, wood product than plywood.
Plywood is made up of 3, 5, or 7 plys of wood shaved off a log and glued together with each layer having the grain running in opposite directions for strength and stability.
Luan is made up of two outer layers of wood shaved similar to plywood. The big difference is the core of the product which seems to be an end grain slice of wood which is just a filler to make the product the appropriate thickness but doesn't add much strength. Luan is generally made of softer wood than plywood, but is has a much smoother, sanded, surface than plywood.
Bottom line, its cheaper than 1/4" plywood, smoother surface, and strong enough for Vex.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 18-09-2006, 08:31
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
I just posted pics of the official field that was debuted yesterday - should be up on CD as soon as approved.
WPI FVC scrimmage photos syraweb FIRST Tech Challenge 0 08-03-2006 09:19
2006 Game - whats on the field? Katy Rumor Mill 4 04-01-2006 17:02
2006 game poll #1 (field size) dhitchco Rumor Mill 18 30-12-2005 23:31
2006 game poll #6 (game shape/object movements on or off field) dhitchco Rumor Mill 0 18-11-2005 12:09
2006 FVC Game to Be Released Tomorrow! artdutra04 FIRST Tech Challenge 6 07-10-2005 23:11
