Light Filter
In the Hangin-A-Round game manual it states that you make use any material used specifically for the light sensor as a filter. How would i go about filtering the colors.
Re: Light Filter
Let's say you want to filter OUT the color yellow. You place a Yellow colored piece of something transparent over the thing doing the looking, and the yellow material makes all things that are yellow appear to be the same as things that are white.
Try it. Find something colored and transparent, and look at the world through it. Green is especially weird outside. You may note that the "filter" doesn't exactly cancel out the color, you can tell a difference between the colored item and a white item. That is because the color of your filter is not exactly correct. People in the photography world use colored plastic sheets, thin like an overhead transparency, available in literally thousands of different colors, for exactly this purpose. Go to a high-end photography store - not a chain store - and someone will surely send you in the right direction. Hope this helps Don |
Re: Light Filter
Some stage lighting companies use to sell sample books of what are known as lighting gels. They were about business card sized samples of gel filters used on theatrical lighting. Hopefully, those sample books are still available. You'd have a lifetime supply of filter material for a vex light sensor, and in every color imaginable.
| camera trouble,cant tell the green-light from regular white light | Nimmy | Programming | 26 | 14-01-2007 14:53 |
| FRC analog input RC filter values | Gdeaver | Control System | 2 | 01-01-2006 22:03 |
| Gyro Filter | MikeDubreuil | Electrical | 7 | 04-02-2003 17:26 |
| Now with a competition filter!!! | archiver | 2001 | 0 | 24-06-2002 02:10 |
| Broken Light | archiver | 2001 | 1 | 24-06-2002 01:01 |
