Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 21-09-2006, 07:45
Cirrussport Cirrussport is offline
Cirrussport is an unknown quantity at this point
victor 885 parts
I know they arent used in first but does anyone have a victor 885 that they could pull a part number off for me if its possibly visible?
I need the part number for the fets used.(these are the parts under the fan)
Thanks so much
Unread 29-09-2006, 00:43
Re: victor 885 parts
http://www.chiefdelphi.com/forums/at...tid=4638&stc=1
I know this isnt a picture of the blown up parts. this picture only shows where I removed one Mosfet.
Im still having camera problems so this is a pic from a few weeks ago.
Sorry for the delay. Im workin on more pics
Unread 29-09-2006, 07:30
This is actually a good picture showing the debris carried in by the fan. I have often found metal grit on the board at this point when opening suspect controllers. Teams are shocked by the amount of stuff once I open one of their controllers.
Unread 29-09-2006, 20:04
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Very good photo. I have suspected this condition on many occasions; as Al says it is very likely the leading cause of Victor failure.
The moral of this story is: don't make chips and metal dust around the electrical system. You may think you've cleaned it up afterwards, but that's actually somewhere between extremely difficult and totally impossible.
Richard Wallace
since 2003
Unread 21-09-2006, 08:34
Victor 885's use International Rectifier IRF3703 FETs.
Unread 21-09-2006, 09:53
awesome, thank you so much.
Do you know if they use the same Pic micro controller?
Ive tried to find the microcontroller with some success. Just trying to replace blown parts on one. The microcontroller isnt blown but i wouldnt mind getting a backup to copy the program too.(you never know what could happen)
Unread 21-09-2006, 12:26
I don't know which microprocessor is used in the Victors. I remember locating it on an 883 or 884, but I don't think I went so far as to figure out which model it was. The program is not in the microprocessor, but on a nearby firmware chip. If any of that blows you've got bigger problems than replacing the microprocessor.
Unread 21-09-2006, 15:13
It seems that I remember reading a statement somewhere that the 885 is a different beast than the 884. Besides the fact that it uses the higher voltage FET.
Unread 21-09-2006, 15:41
i didnt notice any firmware chip. The microprocessor has all the built in memory and space to store the program.I see a few voltage regulators, 12 mosfets. A Capacitor. A few small other chips(i dont have one on me right now but i didnt think i saw a firmware chip. Theres also a few little pieces like the frequency chip which i believe runs the mosfets. Altho there are tons of little resistors.
I just have like 6 victors sitting around that are blown and want to fix them. There mostly 883's but thought i may be able to replace the mosfets with higher voltage mosfets to stop them from igniting and burning out. I dont know how well it will work but i think its worth a try. Unless someone else has tried it
Thanks
Craig
Unread 21-09-2006, 15:59
Forget what I said about the firmware chip. I was thinking of another system and confused myself.
There is more to blowing up FETs than their individual ratings. Put too powerful a FET in as a replacement and the rest of the Victor won't be able to handle it.
I agree with Al's comment that the 885's are a different beast. They handle higher power because they are designed for it with features other than "bigger" FETs.
Usually, the FETs short when metal shavings or particles fall into them. Bigger FETs might just release more magic smoke.
Unread 21-09-2006, 16:06
Originally Posted by Mark McLeod
... There is more to blowing up FETs than their individual ratings. Put too powerful a FET in as a replacement and the rest of the Victor won't be able to handle it. ...
FET's that are rated for higher breakdown voltage and/or for lower on-state resistance will also have higher gate capacitance. A driver circuit that is correctly sized for a lower-rated FET may not provide sufficient gate current to fully saturate a larger FET within the same switching interval; this would result in higher switching losses, so the larger FET might actually run hotter, depending on the chopping frequency. As Mark says, you should not try to soup-up a Victor by simply changing out FETs -- you have to consider the whole circuit.
[edit]666 posts![/edit]
Richard Wallace
since 2003
Unread 22-09-2006, 07:27
Not to pile on here,
As Mark has pointed out, FET death is frequently metal shavings related but all too often, teams are running inefficient designs that have extreme current demands (i.e. constant or near constant stall on a Chalupa will draw 129 amps). It is these extreme currents that raise the internal temperature that explodes the case of the FET. (Note that the FETs are not mounted to heatsinks.) Going to a higher breakdown voltage FET will do nothing for that type of failure. In general, a single FET failure is shavings related and will usually be accompanied by smoke damage near the base of the FET. A failure of six at a time is temperature related and will usually result in damage to the circuit board.
Unread 22-09-2006, 08:46
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
... ... A failure of six at a time is temperature related and will usually result in damage to the circuit board.
Many competing products to Victors protect themselves from thermal destruction by having the micro onboard the Electronic Speed Controller (ESC) monitor current and/or temp flowing through the ESC.
Back when I was a rabid robot warrior, I thought that I wanted every ounce of performance from the ESC. I reasoned that I would rather replace any dead ESC between matches than loose a pushing match because the ESC was protecting itself.
I have since moderated my views. If everyone has the same constraints, it doesn't really hurt the competition to have everyone with a little less current capability in the ESC -- it's just one more constraint everyone has to live with. The main result of an ESC that protects itself would really just be lower sales of ESCs because fewer die and teams don't have to buy replacement/extra ESCs.
Bottom line, I think it is a good idea for ESC's used in FIRST to have internal thermal protection.
Joe J.
Team #88, TJ2
Unread 22-09-2006, 10:43
i fully agree with the thermal protection idea. i have so many dead victors sitting around just because of over current. I wouldve much rather had the victor limit the current or cut out because of heat then had to replace them. Thermal protection should definately be considered.
I like the overall victor design. but thermal protection would be great.
I know it wouldnt work in first competitions. but i think it would be nice to have a full 2 victor system with mixing capabilitys available for r/c equipment. I like the victors much more than the double esc mixing systems out there
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Image Discuss: Team 885 Teaser 1 CD47-Bot Robot Showcase 1 19-02-2003 12:20
Thanks to 121 and 885 Deej Off-Season Events 5 22-05-2002 08:45
Team 885 PsychoPhil Robot Showcase 5 23-04-2002 09:53
Segway on Team 885 ;-) PsychoPhil Dean Kamen's Inventions 1 22-04-2002 21:14
