Ok, so we have till the end of monday to get the robot to work,
I'm the new replacement programmer, and I cant get the loader to work. It's been really bugging me. It opens, and I click "Browse". When I click on the camera.hex file and press open, I get an alert message. This is about what it reads: Run-Time Error "76" Then when I press "OK" It closes IFI Loader. Could someone please at least give me a hint as to what I should do? Any help you give would be, well... helpful. Thank You! ![]() |
Re: IFI Loader doesnt open .hex file
Try moving the camera.hex file to a different directory. I believe that Runtime Error 76 in VB6 means that the directory wasn't found. It could be because it's too long of a path.
Thanks Matt!
I've had problems like that before, so your probably right. Now I'm ganna burn with anxiety waiting till monday to try it out. ![]() |
76 -- Path not found
Yes, move the hex file to a shallower directory. IFI_Loader can't read long file names. I would recommend moving your whole programming folder further down the file tree.
Errr, it didn't work, can you maybe give step by step directions?
Would be very appreciated ![]() |
#7
btw: the file with the location is 31 characters long:
C:\mcc18\frc_camera\camera.hex and the full alert message is: Run-time error '76': Path not found after this alert comes up, it exits the Ifi_loader program ![]() |
#8
Ok, sorry for posting 3 times in a row, but i just found this link:
http://www.ifirobotics.com/forum/viewtopic.php?t=96 It's about how the loader only accepts files under 32k. I have a feeling mine is 70k, but I'm working on that. If anyone's got suggestions, they would be appreciated A LOT AND BUNCH! |
#9
or... maybe not?
program memory utilization is 19% well.. the .hex file is 70k, but the program is apparently not but i figured the problem, i was using another copie of IFI_loader, so i have that down. but now, when i press download, (ive pressed the prog button) it says "device found" untill i get an alert- Runtime error "11" Division by Zero any ideas about what this means? (sorry about all the posts) Last edited by travmizer : 02-10-2006 at 17:42. |
#10
If you're feeling brave, you can try PICLoader or pycloader (C vs. Python). http://sf.net/projects/ifi-picloader I wrote pycloader, so any problems you have with it I'd love to hear about. (I think it might be better implemented than the original IFI loader.) |
#11
Im glad you have found a solution but please learn to use the edit button. 5 posts is a little much.
| I cant get my program into a hex file | Serge | Programming | 8 | 17-02-2006 03:28 |
| Hex file downloads | Ryan M. | Control System | 2 | 29-10-2005 19:50 |
| hex file garbage? | sciguy125 | Programming | 2 | 04-07-2005 23:04 |
| IFI Loader problem - "Invalid HEX file" | wun | Programming | 9 | 22-09-2004 12:35 |
| How do we convert a modified user routines file into a valid .HEX file | HuskieRobotics | Programming | 13 | 28-02-2004 12:12 |
